DHCP Relay Agent Configuration
abdul.imran523
Please provide me guidance inorder to achieve the above task:
In My head office on Core switch :: so many vlan have already configured (up to 15 vlans )
My requirement is vlan 10 and its ip 172.x.x.x to be able to configure in brach network for only 3 pc ( in Branch network we have already two vlans )
i didnt configure anything in core switch
when i was try to configure the relay agent on branch switch ; unable to assign the following
#conf t
# int vlan 10
# ip dhcp relay enable
the above command give me the error;
please help me for the above commands
7 Replies 7
Bilal Nawaz
Hello, Please try using the 'ip helper-address x.x.x.x'
where x.x.x.x is your DHCP server IP address.
See here for more info: http://www.ciscopress.com/articles/article.asp?p=330807&seqNum=9
http://cisconet.com/tcpip/dhcp/107-how-to-use-ip-helper-address-to-connect-remote-dhcp-server.html
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Can you  please tell me where can i configure this (Ip helper-address x.x.x.x ) i mean on branch side switch or router ?
You need to configure this on the interface wherever the default gateway will be for the clients/pc's.
Hope this helps
Friend im not expert in cisco im just beginner,
suppose iam getting the ip from swtich :
Switch# conf t
          # int fa 0.1
          # ip helper-address X.X.X.X
Please provide me some commands
Apologies Mohd, I am not able to tell you the exact configuration since you havent told me where the default gateway will be for your PC's.
Is your 2960 switch just purely an access switch, is everything in the same vlan?
If i assume this, then your configuration will need to be on the 2800 series router, on the interface that connects to the 2960.
So on the 2800 you do this:
interface fa0/1
ip address x.x.x.x y.y.y.y
ip helper-address z.z.z.z
where z.z.z.z is your DHCP server.
I hope this explains a little better.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please see the below configuration of router: i have only two ports - 1 for isp and 2nd for switch
where as switch having 24 ports
interface FastEthernet0/0
ip address X.X.X.X   X.X.X.X
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $ES_LAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1.111
description Voice Vlan
encapsulation dot1Q 111
ip address 10.X.X.254 255.255.255.0
ip nat inside
no cdp enable
interface FastEthernet0/1.211
description Data Vlan
encapsulation dot1Q 211
ip nat inside
no cdp enable
Okay, thank you - this is what needs to be done on the 2800:
Conf t
Please ensure that you have connectivity from your router to the DHCP server for this to work.
Hope this helps.
