Prefer BGP route and questions
nkillgore
Here is my bgp config. How do I prefer the routes from the 200.30.6.225 neighbor over the ones received from the 200.30.6.229 neighbor?
router bgp 1000
no synchronization
bgp router-id 200.30.6.226
bgp log-neighbor-changes
bgp deterministic-med
network 10.3.2.0 mask 255.255.254.0
network 172.16.1.0 mask 255.255.255.0
neighbor 200.30.6.225 remote-as 2828
neighbor 200.30.6.225 transport path-mtu-discovery
neighbor 200.30.6.225 description MPLS
neighbor 200.30.6.225 send-community
neighbor 200.30.6.225 soft-reconfiguration inbound
neighbor 200.30.6.229 remote-as 2828
neighbor 200.30.6.229 transport path-mtu-discovery
neighbor 200.30.6.229 description DMZ
neighbor 200.30.6.229 send-community
neighbor 200.30.6.229 soft-reconfiguration inbound
neighbor 200.30.6.229 distribute-list BLOCK_BGP_TO_DMZ in
neighbor 200.30.6.229 distribute-list BLOCK_BGP_TO_DMZ out
no auto-summary
Extended IP access list BLOCK_BGP_TO_DMZ
    10 deny ip 10.0.0.0 0.255.255.255 any (1976 matches)
Dennis Mink
Use local preference, to distinguish between the two.
For example, you wanted to prefer the neighbor 200.30.6.229
routerbgp1000
neighbor 200.30.6.225 route-map LOWPREF in
neighbor 200.30.6.229  route-map HIGHPREF in
route-map LOWPREF permit 10
set local-preference 90
route-map HIGHPREF permit 10
set local-preference 110
Highest local preference is most preferred.
Please remember to rate useful posts, by clicking on the stars below.
Jan Hrnko
Level 4
Level 4
if your neighbors are advertising routes to the same destination, then you can locally prefer one neighbor over another using WEIGHT attribute.
Default value is 0. Higher value is more preferred.
For example:
Router(config-router)#neighbor 200.30.6.225 weight 100
Check this link for more information:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml#weight
Best regards,
Jan
If you want to prefer the route on this router only, then use WEIGHT, as long as it's a Cisco router. If it needs to be prefered for the entire local AS, then use LOCAL_PREFERENCE.
Obviously this is only for outbound preference.
I didn't both showing any configuration, since these two guys that posted ahead of me, did a good job.
