Priority queue on Tunnel interface
Hi. I need to set priority queue on tunnel interface, to make some traffic class served first, the other one next and remaining the last.
I understand what i should create shaping policy map to specify tunnel bandwidth, but what's next?
16 Replies 16
hi,
i thought it used for EIGRP metrics only
QoS and traffic shaping applied to the interface will use the configured bandwidth for percentage calculations. "bandwidth" statement on interfaces is used for several things.
1. Dynamic routing protocols(eigrp, ospf) use the interface bandwidth for path selection. Manually specifying the "bandwidth" to something sane for the physical path over which the tunnel rides may be needed for proper route selection.
2. QoS and traffic shaping applied to the interface will use the configured bandwidth for percentage calculations.
Kishore
Does the order of statements in my example matters?
