ip address layer 3 and WAN dhcp
pcfreak49
I have a problem with a layer 3 swiches ports that would have an ip address 100.100.100.1 255.255.255.0 and get the wan port would have a Publik via dhcp so then the remote swichtes lied to on a port above the 1023
how can you do this running-config
10 Replies 10
CSCO11593588
Hi you have configured wrong IP address under interface VLAN 1, instead of (100.100.100.1 /24)
interface Vlan1
ip address 100.100.10.1 255.255.255.0
I changed that but I always get the ip address Publik be displayed instead of the dhcp ip address how can you solve this
will in this case we may help you if you post your running config one more time.
maybe get a little bit clearer about the issue by posting show commands output and  what he thinks should appear instead.
But I don't see any  ip add dhcp command and what is this Publik and maybe post a diagram with the other gears involved.
Regards.
Alain.
This current-running
you're acting as a dhcp server so what is the problem? your machines don't get IPs?
Regards.
Alain.
The clients get an ip address 100.100.100.1 255.255.255.0 and it works but if I no wan port cabin please get this interface overrides the DHCP server how can you solve that
I don't understand.
Alain.
if I update the internal dhcp server ip address if I wan port then do no shut the dhcp server does not
hmm...dont take this the wrong way but are you using some kind of language translator to post in english?
