Problem linux client SMTP
bagnolini
Level 3
Level 3
I've a strange problem with smtp on linux machine, this is the architecture:
- Router 877 with ADSL
- Windows client are able to send and receive email
- Linux client are able only to receive the mail (not send)
This is the config:
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname ADSL-Log80
boot-start-marker
boot system flash c880data-universalk9-mz.152-2.T.bin
boot-end-marker
logging buffered 52100 warnings
enable secret 5 $1$/Ej2$ughU.MiSCui0hKYELT8pv0
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
memory-size iomem 10
clock timezone CET 1 0
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip inspect name Firewall dns
ip inspect name Firewall ftp
ip inspect name Firewall h323
ip inspect name Firewall https
ip inspect name Firewall icmp
ip inspect name Firewall imap
ip inspect name Firewall netshow
ip inspect name Firewall rcmd
ip inspect name Firewall realaudio
ip inspect name Firewall rtsp
ip inspect name Firewall esmtp
ip inspect name Firewall sqlnet
ip inspect name Firewall streamworks
ip inspect name Firewall tftp
ip inspect name Firewall tcp
ip inspect name Firewall udp
ip inspect name Firewall vdolive
ip inspect name Firewall sip
ip inspect name Firewall sip-tls
ip cef
no ipv6 cef
license udi pid CISCO887-K9 sn FCZ154693WD
license accept end user agreement
no spanning-tree vlan 1
vtp mode transparent
username administrator privilege 15 password 0 log80
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
description Adsl-Telecom
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description LAN Interna
ip address 172.28.98.4 255.255.255.0 secondary
ip address 192.168.17.1 255.255.255.0
ip access-group INSIDE in
ip nat inside
ip virtual-reassembly in
interface Dialer0
ip address 109.238.xx.xx 255.255.255.254
ip access-group OUTSIDE in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip inspect Firewall out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxx
ppp chap password 0 yyyyyyy
ppp pap sent-username xxxxxxx password 0 yyyyyy
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip nat inside source static tcp 192.168.17.2 22 interface Dialer0 22
ip nat inside source static tcp 192.168.17.2 80 interface Dialer0 80
ip nat inside source static tcp 192.168.17.2 443 interface Dialer0 443
ip nat inside source route-map NONAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended INSIDE
remark Block Outbound
deny   ip any 69.63.176.0 0.0.0.255
deny   ip any 66.220.0.0 0.0.255.255
deny   ip any 66.171.224.0 0.0.31.255
deny   ip any host 78.46.67.20
permit ip any any
ip access-list extended OUTSIDE
permit ip 195.234.232.0 0.0.3.255 any
permit tcp any host 95.254.31.202 eq www
permit tcp any host 95.254.31.202 eq 22
permit tcp any host 95.254.31.202 eq 443
permit tcp any host 109.238.18.20 eq www
permit tcp any host 109.238.18.20 eq 22
permit tcp any host 109.238.18.20 eq 443
access-list 2 permit 192.168.235.28
access-list 2 remark Gestione Accessi Telnet
access-list 2 permit 195.234.232.0 0.0.3.255
access-list 2 permit 192.168.13.0 0.0.0.255
access-list 2 permit 192.168.17.0 0.0.0.255
access-list 2 permit 172.28.98.0 0.0.0.255
access-list 110 remark Gestione Nat verso Internet
access-list 110 permit ip 192.168.13.0 0.0.0.255 any
access-list 110 permit ip 192.168.17.0 0.0.0.255 any
route-map NONAT permit 10
match ip address 110
snmp-server community public RO
snmp-server ifindex persist
paolo bevilacqua
int vlan 1
ip tcp mss-adjust 1452
Also you don't need access group when using NAT.
paolo bevilacqua
int vlan 1
