problem to configure 2x ISR cisco 886 in ISDN
nvanhaute
I'm trying to configure 2 routers (cisco 886) to create a link between them via ISDN link (in france) but it doesn't work
I think I put a base conf but nothing work :
LAN 1 (192.168.220.0/24) => BRI0 (172.23.240.1) Cisco 886 <= ISDN =>  BRI0 (172.23.240.2) Cisco 886 => LAN 2 (192.168.255.0/24)
both conf are about the same (not IP and phone number) :
interface BRI0
ip address 172.23.240.1 255.255.255.0
encapsulation ppp
dialer idle-timeout 600
dialer string xxxxxxxxxxxxx
dialer-group 1
isdn switch-type vn3
isdn termination multidrop
isdn point-to-point-setup
ppp authentication chap
interface Vlan1
ip address 192.168.220.254 255.255.255.0
ip route 0.0.0.0 0.0.0.0 172.23.240.2
dialer-list 1 protocol ip permit
I will add more later an authentication.
Si if you have an idea, that would be great.
Nicolas
Giuseppe Larosa
Hello Nicolas,
I would try after removing the lines
interface bri0
no isdn point-to-point-setup
no isdn termination multidrop
These are not needed in a minimal configuration.
To see what happens you can use
show isdn status
This show is very handy as it shows ISDN Layer1, Layer2, Layer3
debug isdn q921
debug isdn q931
debug ppp negotiation
debug ppp authentication
debug dialer
you need to trigger a call pinging a remote destination
see the following documents
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1917.html
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094bb8.shtml
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Nicolas,
interface bri0
show isdn status
debug isdn q921
debug isdn q931
debug dialer
Hope to help
Giuseppe
Hi Giuseppe,
I found my solution in adapting this one :
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080094cd6.shtml
all is now OK
Thanks for your help
Nicolas
Hi Nicolas,
Can you post your current working configuration so we can compare the changes? Thanks!
Best regards,
Peter
Hi Peter,
sure, see interesting lines below :
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
ppp authentication chap pap callin
interface Vlan1
interface Dialer1
description vers CLG
encapsulation ppp
dialer pool 1
dialer remote-name CLG285-RN01
dialer idle-timeout 180
dialer-group 1
ppp authentication chap callin
ip route 0.0.0.0 0.0.0.0 Dialer1
Nicolas
Hi Nicolas,
Wonderful, thanks! So you basically moved away from configuring the physical BRI interface (a so-called "Legacy DDR" approach) and instead you moved to Dialer profiles. Very good.
Best regards,
Peter
