Problem with 1911 ISRG2 and 3G ehwic.
Emperor2000
hello iam working on setting up a 1911 router with a EHWIC-3G-HSPA+7.
I have searched different guides for how to set this up.
Config looks like this.
chat-script hspa "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
interface Loopback1
ip address 10.10.10.1 255.255.255.255
interface Cellular0/0/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string hspa
dialer-group 1
async mode interactive
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
dialer-list 1 protocol ip permit
line 0/0/0
exec-timeout 0 0
script dialer direct-ip
modem InOut
no exec
Router#sh cellular 0/0/0 all
Hardware Information
Modem Firmware Version = T1_0_3_2AP R361 CNSZ
Modem Firmware built = 04/15/11
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 240029803040651
International Mobile Equipment Identity (IMEI) = 357115040235926
Integrated Circuit Card ID (ICCID) = 8946071207220086210
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Factory Serial Number (FSN) = CC3157202581007
Modem Status = Online
Current Modem Temperature = 28 deg C, State = Normal
PRI SKU ID = 9900198, SKU Rev. = 1.2
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = bredband.tre.se
Authentication = PAP
Username: '', Password: xx
Profile 16 = INACTIVE
PDP Type = IPv4
Authentication = None
Username: , Password:
* - Default profile
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = HSDPA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = SWE, Network = SWE
Mobile Country Code (MCC) = 240
Mobile Network Code (MNC) = 4
Location Area Code (LAC) = 2362
Routing Area Code (RAC) = 1
Cell ID = 23182
Primary Scrambling Code = 182
PLMN Selection = Automatic
Registered PLMN =  , Abbreviated =
Service Provider = 3
Radio Information
Radio power mode = ON
Current Band = WCDMA 2100, Channel Number = 10638
Current RSSI = -97 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
        Primary Scrambling Code = 0xB6
        RSCP = -96 dBm, ECIO = -3 dBm
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
However im unable to connect with ping
Router# ping 4.4.2.2
Sending 5, 100-byte ICMP Echos to 4.4.2.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
When checing debug logs i find this.
Oct 14 14:12:13.687: Ce0/0/0 DDR: place call
Oct 14 14:12:13.687: Ce0/0/0 DDR: Dialing cause ip (s=10.10.10.1, d=8.8.4.4)
Oct 14 14:12:13.687: Ce0/0/0 DDR: Attempting to dial hspa
Oct 14 14:12:13.687: CHAT0/0/0: Attempting async line dialer script
Oct 14 14:12:13.687: CHAT0/0/0: no matching chat script found for hspa
Oct 14 14:12:13.687: CHAT0/0/0: Dialing using Modem script: d0efault-d0ials0cript & System script: none
Oct 14 14:12:13.687: CHAT0/0/0: process started
Oct 14 14:12:13.687: CHAT0/0/0: Asserting DTR
Oct 14 14:12:13.687: CHAT0/0/0: Chat script d0efault-d0ials0cript started
Oct 14 14:12:13.687: CHAT0/0/0: Sending string: ATZ
Oct 14 14:12:13.687: CHAT0/0/0: Expecting string: OK
Oct 14 14:12:13.699: CHAT0/0/0: Completed match for expect: OK
Oct 14 14:12:13.699: CHAT0/0/0: Sending string: AT
Oct 14 14:12:13.699: CHAT0/0/0: Expecting string: OK
Oct 14 14:12:13.711: CHAT0/0/0: Completed match for expect: OK
Oct 14 14:12:13.715: CHAT0/0/0: Sending string: ATDT\T<hspa>
Oct 14 14:12:13.715: CHAT0/0/0: Expecting string: CONNECT
Oct 14 14:12:13.715: CHAT0/0/0: Found abort string ERROR expecting CONNECT
Oct 14 14:12:13.715: CHAT0/0/0: Chat script d0efault-d0ials0cript finished, status = Connection aborted
Oct 14 14:12:13.715: TTY0/0/0: Line reset by "Async dialer"
Oct 14 14:12:13.715: Ce0/0/0 DDR: disconnecting call
Oct 14 14:12:13.715: TTY0/0/0: Modem: (unknown)->HANGUP
Oct 14 14:12:13.715: TTY0/0/0: no timer type 0 to destroy
Oct 14 14:12:13.715: TTY0/0/0: no timer type 1 to destroy
Oct 14 14:12:13.715: TTY0/0/0: no timer type 3 to destroy
Oct 14 14:12:13.715: TTY0/0/0: no timer type 4 to destroy
Oct 14 14:12:13.715: TTY0/0/0: no timer type 10 to destroy
Oct 14 14:12:13.715: TTY0/0/0: no timer type 2 to destroy
Oct 14 14:12:13.911: TTY0/0/0: dropping DTR, hanging up
Oct 14 14:12:13.911: tty0/0/0: Modem: HANGUP->IDLE
Oct 14 14:12:15.911: TTY0/0/0: restoring DTR
It seems that the string ATDT\T<hspa> dosent work.
Would be great with some helt regarding where to start troubleshooting.
paolo bevilacqua
You need to use a valid chat-script name in 'dialer script'.
paolo bevilacqua
Ahhhh yes staging at the config made me blind. Works now thanks. :)
