problem with access list
goran ljubic
i have access list on cisco router 1921 that connect two networks external 192.168.0.0/24 andinternal 192.168.200.0/24. the access list is set on external port gigabitethernet 0/0 inbound. from computers in network 192.168.0.0/24 i can access to servers in network 192.168.200.0/24, but i cannot access servers to network 192.168.0.0/24. what i must do that i can access to network 192.168.0.0/24 from network 192.168.200.0/24
thanks
configuration of router is
Building configuration...
Current configuration : 9974 bytes
! Last configuration change at 13:53:55 Prague Thu Jul 30 2015 by administrator
version 15.2
service password-encryption
hostname servers-r
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$zUjL$rAvZbXspCYjotGe/jL48T1
enable password 7 097C4F1A0A1218000F4D557878
no aaa new-model
clock timezone Prague 1 0
clock summer-time Prague date Mar 30 2003 2:00 Oct 26 2003 3:00
no ipv6 cef
ip domain name d.l
ip name-server 192.168.0.20
ip name-server 192.168.0.24
ip cef
crypto pki trustpoint TP-self-signed-2259530887
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2259530887
 revocation-check none
 rsakeypair TP-self-signed-2259530887
crypto pki trustpoint test_trustpoint_config_created_for_sdm
 subject-name e=sdmtest@sdmtest.com
 revocation-check crl
crypto pki certificate chain TP-self-signed-2259530887
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32323539 35333038 3837301E 170D3135 30373038 31333139
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 32353935
  33303838 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B259 D0C431C4 B525F2EE 1D9BF630 C149CE34 786795EC B6355D65 A8EF7B3D
  C65EEAC8 729155F5 5BC853AE 976AC249 B40FFED6 59CF457F 0F4FA191 2080218C
  4380C255 33DAEF9C E103307A 69477BC6 5A740E2C D944326B 461DC373 2F1F6CE2
  F1B8C22E A5010323 815804D3 7C3BAFB2 62BC7842 C8D0D506 0FB9CA8B 0F49236E
  AE8B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14A5124D 5912F9BC C4109E65 E49489B7 24AC8345 22301D06
  03551D0E 04160414 A5124D59 12F9BCC4 109E65E4 9489B724 AC834522 300D0609
  2A864886 F70D0101 05050003 81810033 1A9BEBA8 0736025C 5740E525 0A45910B
  406A0CFA F2ADE31F 76D92B73 40EBBF98 F2E261C0 247D6BD9 94D3AE79 313D7AE4
  0CA635B3 A62205B4 67F9CD78 6CD47554 F5F184BD C88BB35C C01E44AD E8491DF7
  0A46F0AF 39867593 6F21B2D3 E8B5B787 D430E64B F3F7A7D3 C2D54690 E31E2B35
  E77E55D8 02E035B1 0965616F 00AC1A
  quit
crypto pki certificate chain test_trustpoint_config_created_for_sdm
license udi pid CISCO1921/K9 sn FCZ163293TE
object-group network DC_0.20
 host 192.168.0.20
 host 192.168.0.24
object-group service SPSQL_server
 description sql server for sharepoint
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 1433
 tcp eq 445
 tcp eq 2383
 tcp eq www
 tcp eq 5357
object-group network SQL_0.34
 host 192.168.0.34
object-group network SQL_servers
 host 192.168.200.14
 host 192.168.200.34
 host 192.168.200.16
object-group service WDS_server
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 5040
 tcp eq 443
 tcp eq 445
 tcp eq 1032
 tcp eq 1039
 tcp eq 1089
 tcp eq www
 tcp eq 5357
object-group network backup_server
 host 192.168.0.152
 host 192.168.0.32
 range 192.168.0.29 192.168.0.30
object-group service backup_servers
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 9876
 tcp eq 445
 tcp eq 2301
 tcp eq 2381
 tcp eq 3260
object-group service domain_controller
 udp eq ntp
 tcp eq 135
 udp eq netbios-ns
 udp eq netbios-dgm
 tcp eq 139
 tcp eq 636
 tcp-udp eq 389
 tcp-udp eq 445
 tcp-udp eq 464
 tcp eq 5722
 tcp eq smtp
 tcp-udp eq domain
 tcp-udp eq 88
 tcp eq 3268
 tcp eq 3269
 tcp range 49152 56535
 tcp eq 3389
 tcp eq 5357
object-group network domain_controllers
 host 192.168.200.20
 host 192.168.200.24
object-group service dri-net_server
 tcp eq 135
 tcp eq 139
 tcp eq 3306
 tcp eq 445
 tcp range 1048 1050
 tcp eq domain
 tcp eq 3289
object-group service finansije_server
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 445
 tcp eq www
 tcp eq 5357
object-group service paragraflex_server
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 445
 tcp eq 5357
 tcp eq 6190
object-group service sharepoint_application_service
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 2103
 tcp eq 2105
 tcp eq 2107
 tcp eq 1801
 tcp eq smtp
 tcp eq 4361
 tcp eq 8080
 tcp eq 4860
 tcp eq 445
 tcp eq 1053
 tcp eq 5357
 tcp range www 82
object-group service sharepoint_web_application
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 2103
 tcp eq 2105
 tcp eq 2107
 tcp eq 1801
 tcp eq 8080
 tcp eq 445
 tcp eq 1044
 tcp eq 1060
 tcp eq 1074
 tcp range 1025 1028
 tcp eq 1102
 tcp eq www
object-group network sharepoint_web_servers
 range 192.168.200.36 192.168.200.37
 host 192.168.200.13
 host 192.168.200.17
object-group service terminal_server
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 1947
 tcp eq 445
 tcp eq 5357
object-group service virtual_server_services
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 2179
 tcp eq 445
 tcp eq 2301
 tcp eq 2381
 icmp echo
 icmp echo-reply
object-group network virtual_servers
 host 192.168.200.11
 host 192.168.200.25
 host 192.168.200.41
object-group network wsus_servers
 host 192.168.200.12
 host 192.168.200.27
 host 192.168.200.15
object-group service wsus_services
 tcp eq 135
 tcp eq 139
 tcp eq 3389
 tcp eq 445
 tcp eq www
 tcp eq 5357
 tcp eq 8531
 tcp eq 443
 tcp eq 8530
 icmp echo
 icmp echo-reply
username administrator privilege 15 password 7 01230717481C091D250D1F5B4A
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-WAN$
 ip address 192.168.0.253 255.255.255.0
 ip access-group domain_controller in
 ip mask-reply
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 description $ETH-LAN$
 ip address 192.168.200.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip route 192.168.50.0 255.255.255.0 192.168.0.10 permanent
ip access-list extended allow_all
 remark CCP_ACL Category=1
 permit tcp any host 192.168.0.26 eq 6190
 permit tcp any host 192.168.0.28 eq 3389 log
 permit tcp any host 192.168.0.33 eq 3389 log
 permit icmp any host 192.168.0.20
 permit ip any any log
ip access-list extended client_domain_controller
 remark CCP_ACL Category=16
 permit tcp 192.168.200.0 0.0.0.255 host 192.168.200.254 eq telnet
 permit tcp 192.168.200.0 0.0.0.255 host 192.168.200.254 eq 22
 permit tcp 192.168.200.0 0.0.0.255 host 192.168.200.254 eq www
 permit tcp 192.168.200.0 0.0.0.255 host 192.168.200.254 eq 443
 permit tcp 192.168.200.0 0.0.0.255 host 192.168.200.254 eq cmd
 deny   tcp any host 192.168.200.254 eq telnet
 deny   tcp any host 192.168.200.254 eq 22
 deny   tcp any host 192.168.200.254 eq www
 deny   tcp any host 192.168.200.254 eq 443
 deny   tcp any host 192.168.200.254 eq cmd
 deny   udp any host 192.168.200.254 eq snmp
 permit tcp host 192.168.200.20 any range 49152 56535 established log
 permit udp host 192.168.200.20 any range 49152 56535 log
 permit tcp host 192.168.200.41 any eq 3389
 permit udp host 192.168.200.20 any eq domain log
 permit tcp host 192.168.200.20 any eq domain established log
 permit ip any any
ip access-list extended domain_controller
 permit tcp host 192.168.0.61 host 192.168.0.253 eq telnet
 permit tcp host 192.168.0.61 host 192.168.0.253 eq www
 permit tcp host 192.168.0.61 host 192.168.0.253 eq 443
 permit udp host 192.168.0.24 eq domain any
 permit udp host 192.168.0.20 eq domain any
 permit object-group terminal_server any host 192.168.200.22 log
 permit object-group dri-net_server any host 192.168.200.31 log
 permit object-group paragraflex_server any host 192.168.200.26 log
 remark SPSQL_server
 permit object-group SPSQL_server any object-group SQL_servers log
 permit object-group backup_servers any object-group backup_server log
 permit object-group virtual_server_services any object-group virtual_servers log
 permit object-group WDS_server any host 192.168.200.28 log
 remark wsus servers
 permit object-group wsus_services any object-group wsus_servers log
 permit object-group sharepoint_web_application any object-group sharepoint_web_servers log
 permit object-group finansije_server any host 192.168.200.23 log
 remark sharepoint_application_server
 permit object-group sharepoint_application_service any host 192.168.200.33 log
 remark active_directory
 permit object-group domain_controller any object-group domain_controllers log
 remark ping na sharepoint
 permit icmp host 192.168.0.33 any log
 permit tcp host 192.168.0.40 eq www any log
 deny   udp any host 192.168.0.253 eq snmp
 deny   tcp any host 192.168.0.253 eq cmd
 deny   tcp any host 192.168.0.253 eq 22
 deny   ip 192.168.0.0 0.0.0.255 192.168.200.0 0.0.0.255 log
ip access-list extended insideinterface_out
 permit ip any host 192.168.200.17
ip access-list extended sql
 permit ip any host 192.168.0.34
 permit tcp any host 192.168.0.34
 permit ip any host 192.168.0.61
 deny   ip any any
access-list 1 permit 192.168.0.61
access-list 1 remark Auto generated by SDM Management Access feature
access-list 1 remark CCP_ACL Category=1
access-list 1 permit 192.168.200.0 0.0.0.255
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark CCP_ACL Category=1
access-list 100 permit ip 192.168.200.0 0.0.0.255 any
access-list 100 permit ip host 192.168.0.61 any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class 100 in
 exec-timeout 40 0
 privilege level 15
 login local
 transport input telnet ssh
scheduler allocate 20000 1000
end
    5 Replies 5
    Tagir Temirgaliyev
    all to all
    or
    host to host ?
    Host to host
    conf t
    no ip access-list extended domain_controller
     remark SPSQL_server
     remark wsus servers
    permit ip host 192.168.0.a host 192.168.200.b
    exit
    wr
    Access list for network 192.168.0.0 to gost to 192.168.200.0
    Sorry I need access list for accessing from network 192.168.200.0 to network 192.168.0.0 host to host
    thanks
