Problem with configuring Cisco router 857
itsupport
I am very new in Cisco and this is a first time that I've received task to configure it. This is going to be my backup router in case one of 2 existing Cisco 857 routers fails. I will keep new router off-line but first I would like to configure it and test it.
Task looked straight forward as I could see the other routes settings. I configured all settings via Cisco CP Express to much with my original router 192.2.1.254. Once I swapped routers over for a test my new router didn't get CD and PPP light. Username and password are confirmed that they should be fine.
The option which I don't understand much is encapsulation. On my original router I have selected PPPoA(AAL5MUX).
Also in routing I have selected Dialer0 same like on my original router.
I noticed that when I changed encapsulation to PPPoE, green lighs against CD and PPP appeared . Well I tought problem must be something regarding that option but I can't understand that even when I got CD and PPP green I still couldn't connect to internet. Well then tried to come back to
PPPoA(AAL5MUX). This time all green light stayed on (CD and PPP). Unfortunately I am still unable to connect even if router says in overview "Internet (WAN) up
Once I connect router to the internet I would like to configure firewall and some security using SDM but at the moment I have problem with configuring simple WAN setting in Cisco CP Express. Could you please advise what can I do to compare 2 routers more in detail and see what's different between them.
Dragan
20 Replies 20
paolo bevilacqua
All is done by checking configuration and show commands. For example, to report problem you post configuration here.
This is config of my new router......
Username: admin
Password:
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
new254#show startup-config
Using 3308 out of 131072 bytes
version 12.4
no service pad
hostname new254
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$hpKF$Rc1tl6r45J8iHG7EN5jSk.
no aaa new-model
crypto pki trustpoint TP-self-signed-3185909327
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3185909327
revocation-check none
rsakeypair TP-self-signed-3185909327
crypto pki certificate chain TP-self-signed-3185909327
certificate self-signed 01 nvram:IOS-Self-Sig#A.cer
dot11 syslog
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.2.1.1 192.2.1.129
ip dhcp excluded-address 192.2.1.141 192.2.1.254
ip dhcp pool ccp-pool
   network 192.2.1.0 255.255.255.0
   default-router 192.2.1.254
   lease 0 2
ip cef
username dinicd privilege 15 password 0 Password
username admin privilege 15 secret 5 $1$xMuk$kvmTS1F.KZaCohsbvmbUT1
archive
log config
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$
ip address 192.2.1.254 255.255.255.0
ip virtual-reassembly
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname elc@gibnet.gi
ppp chap password 0 oooo
ppp pap sent-username elc@gibnet.gi password 0 oooo
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface ATM0.1 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner exec ^C
this session.
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
new254#
You can check "show dsl interface" and then ppp debugs.
Also, you need to add nat configuration. There are many similar threads, just use search-
Can't say anything configuration seems perfect for ATM...
But You can use few very specific commands like --
debug ppp authentication
debug ppp negotiation
debug ppp packet.
And also check the show int dsl int at0, it will give the overview of Activation, dsl parameters and errors on line if any.
Hope this would be helpful.
Amit
Please rate helpful posts.
I will try to find something if I have some spare time unfortunately it is a lot of reading and it is not very simple to find exactly the same problem. I am supporting a lot of clients which means my time is limited so I would really appreciate that you save me some time and help me. It is really much easier to fix something if you have live discussion and exchanging your tought.
thanks and regards
Dragan
Can you please post the output of all commands...
and share any gmail account username if u access to ur office...as I am in office and can not support u via skype kind of thing but yes if u can give me your gmail id then i can try to ping you from here..
Here is the output of your 3 commands:
new254#debug ppp authentication
PPP authentication debugging is on
new254#debug ppp negotiation
PPP protocol negotiation debugging is on
new254#debug ppp packet
PPP packet display debugging is on
new254#
How are you connected to the router?  telnet or console ? if telnet then do these commands:
-enable
-terminal monitor
-conf t
- logging monitor debug
Then shut your atm interface then no shut it and you should see the logs from the debug commands.
note: the  NAT overload  should point out dialer interface not atm  and you should notify the router which interface is inside and which is outside relating to NAT:
int vlan 1
ip nat inside
int dialer0
ip nat outside
Regards.
Alain
I connect to the router via Hyper Terminal. Are above commands are going to work?
What do you mean by saying shut your atm interface? Please let me know what commands I need to execute after:
-enable
-terminal monitor
-conf t
thanks
Dragan
Here is my gmail address.
ddinic@n-wss.co.uk
Dragan
Hi Dragon,
I m still confused why ur ATM link not coming up.
Did u recieve any output of the all debug commands ...?? Your configuration seems perfect and this is same config i m using on my customer's WAN over DSL line thru Dialer profile.
And it is working fine though.
If this is still an issue then ...
try to run below command one more time and give me the output--
Can you give me virtual interface output that is made by the ATM ---
I dont know which virtual access- number created by the ATM..
Do a show ip int brief
and you will the the virtual-access interface there..
Give me the output of all virtual-access interface running in router...
use "show int virtual-access [number]" command and post ur output here pls..
Amit Kumar
Here is the configuration of the working router which I need to clone and configure my new backup router:
new254>enable
Password:
Using 3883 out of 131072 bytes
version 12.4
no service pad
hostname new254
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$O3Lm$pbIf/qzdRp///8fa3KZTf1
enable password cisco
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
dot11 syslog
ip dhcp pool POOL-DHCP
   dns-server 85.115.130.4
ip cef
ip dhcp-server 192.2.1.253
username andymac privilege 15 secret 5 $1$o48f$XA7NQH51HByvxyB0Qp2vQ.
username admin privilege 15 password 0
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group all
key hello
pool SDM_POOL_1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ctcp port 10000
archive
log config
  hidekeys
ip telnet source-interface Vlan1
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
logging event atm pvc state
load-interval 30
pvc 0/38
dsl operating-mode ansi-dmt
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
load-interval 30
interface Dialer0
description ADSL PPPoA
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
no cdp enable
ppp ipcp dns request
ip local pool SDM_POOL_1 192.2.1.170 192.2.1.175
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
ip route 10.0.0.0 255.255.255.0 192.2.1.107 permanent
ip route 10.1.0.0 255.255.255.0 192.2.1.107 permanent
ip route 10.2.0.0 255.255.255.0 192.2.1.107 permanent
ip route 10.6.0.0 255.255.255.0 192.2.1.107 permanent
ip route 10.7.0.0 255.255.255.0 192.2.1.107 permanent
ip route 10.8.0.0 255.255.255.0 192.2.1.9 permanent
ip route 10.20.0.0 255.255.255.0 192.2.1.7 permanent
ip route 10.55.0.0 255.255.255.0 192.2.1.28 permanent
ip route 192.2.1.0 255.255.255.0 192.2.1.253 permanent
ip route 192.2.3.0 255.255.255.0 192.2.1.107 permanent
ip route 192.3.1.0 255.255.255.0 192.2.1.253 permanent
ip route 192.168.1.0 255.255.255.0 192.2.1.107 permanent
ip route 192.168.2.0 255.255.255.0 10.0.0.2 permanent
ip route 192.168.5.0 255.255.255.0 192.2.1.28 permanent
ip route 192.168.6.0 255.255.255.0 192.2.1.28 permanent
ip route 192.168.10.0 255.255.255.0 192.2.1.253 permanent
ip route 192.168.20.0 255.255.255.0 10.1.0.2 permanent
ip http server
no ip http secure-server
ip nat inside source route-map SDM_RMAP_2 interface Dialer0 overload
logging trap debugging
logging 192.2.1.253
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.2.1.0 0.0.0.255
access-list 100 remark SDM_ACL Category=18
access-list 100 deny   ip 192.2.1.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 permit ip any any
snmp-server community public RO
route-map SDM_RMAP_2 permit 1
match ip address 100
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
end
Hello again,
I am sorry for delaying this discussion but I was busy with some other clients. Here is what I got from your debugging commnads:
new254#enable
new254#terminal monitor
% Console already monitors
new254#conft
Translating "conft"...domain server (255.255.255.255)
% Unknown command or computer name, or unable to find computer address
new254#logging monitor debug
% Invalid input detected at '^' marker.
new254#
