Problem with Console Server TTY line
navneet_78
I have a 2811 cisco console router running IOS c2800nm-advipservicesk9-mz.124-3b.bin. There are 2 3845 WAN GWs and 1 3750 switch connected to this console server using CAB-HD8-ASYNC cables.
Everytime i have to manually clear the TTY sessions to login into any of the devices connected to the console server.
Is there a default time after which the TTY sessions get cleared normally? I generally log out properly using Ctrl+Shift+6+X.
Please advise.
Cheers
Navneet
8 Replies 8
navneet_78
Appreciate if someone would reply to my above query.
Thanks in advance
Navneet
Navneet,
When you do Ctrl+Shift+6, X it does not log you out of the device but takes you back to the device from where you initiated the connection.
My suggestion would be configure idle timeouts in the 3845 and 3750 devices
line con 0
exec-timeout 5 0
This will log anyone out if the connection is idle for 5 mins
HTH, rate if it does
Narayan
Hi Narayan,
I have tried putting in the exec-timeout 5 0 command on the 3845 and 3750 switch. But still I see TTY lines in the console.
xxxxxxxxxx#sh users
Line User Host(s) Idle Location
tty 0/0/0 idle 00:00:32
tty 0/0/1 idle 00:00:17
* vty 322 xxxxxxxx idle 00:00:00 x.x.x.x
Interface User Mode Idle Peer Address
xxxxxxxxxx#
Can you try reducing the idle timer to some seconds value
exec-timeout 0 10
Narayan
Hi, navneet
Type "show session" command on your console server and see which session number correlates to which device. Then type that session number, e.g. 1,2,or 3. this will bring you directly to that device again. It is not necessary to clear the line then login again.
SSLIN
When i type in the "show session" command, I do not see any connections open.
xxxxxx#sh session
% No connections open
xxxxxx#
But, it gives me 2 TTY lines in the "sh users" command.
xxxxxxxxxx#sh users
xxxxxxxxxx#
Navneet
As has been pointed out Ctrl+Shift+6+X suspends the reverse telnet and returns you to the terminal server but does not really log you out. I would suggest that after the Ctrl+Shift+6+X you enter the disconnect command which will terminate the session. If you do this you should not then have to clear the line to start a new session.
Rick
Rick
you can also use the session-timeout and no exec commands on the interface to automatically disconnect after a set time of inactivity. The following commands will disconnect the line after 10 minutes of inactivity:
session-timeout 10
no exec
