Problem with LAN-to-LAN IPsec Tunnel Between Two Routers
n1c0la5va55al
Here is the situation:
A CISCO871 router is configured to establish an IPSEC tunnel with a CISCO ASA5520. The configuration is ok about that.
I wish to configure the same CISCO871 in order to establish a LAN-to-LAN IPsec Tunnel with another CISCO871 at the same time in order to reach private network. So, I have followed the cisco procedure Document ID: 71462 "LAN-to-LAN IPsec Tunnel Between Two Routers Configuration Example"; it works, I can reach the peer private network BUT ONLY when the IPSEC tunnel with ASA is not established.
It seems to be a routing problem...I don't find how to configure to make both tunnels up and functional at the same time.
Thank you for your help.
Best regards,
paolo bevilacqua
May things can be wrong usually due to configuration mistakes.
If you want a safe and professional results, recommend you hire a certified partner, or reputable consultant for the configuration.
