IP SLA and ROUTE-MAP
Alcides Miguel
Hello!
i need help configuring a route-map to forward traffic to another ISP, i have 3 LINK's in my router 2 of theme are tracked with ip sla for failover porpuse... but i need also to forward email traffic to the 2 line, the 1 line for web and the 3 line i want to use for internal guest web access... failover is working as spected... didin't try yet use the second line for email traffic...
please se config bellow:
ip sla 1
icmp-echo 8.8.8.8 source-interface Dialer0
timeout 500
threshold 150
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 208.67.222.222 source-interface FastEthernet1
timeout 500
threshold 150
frequency 3
ip sla schedule 2 life forever start-time now
ip sla 3
icmp-echo 4.2.2.2 source-interface Vlan31
timeout 1000
threshold 500
frequency 5
ip sla schedule 3 life forever start-time now
track 1 rtr 1 reachability
delay down 15 up 10
track 2 rtr 2 reachability
delay down 15 up 10
track 3 rtr 3 reachability
delay down 15 up 10
interface Vlan27
description *** VLAN_VST_RT ***
ip address 172.16.27.1 255.255.255.252
ip nat inside
ip virtual-reassembly
ip policy route-map VISITORS_POLICY_ROUTE
interface Dialer0
ip address negotiated
ip access-group ACL-INFRASTRUCTURE-IN in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip inspect sec_inspect out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname cuca.bgi
ppp chap password 7 040A59555B741A
ip route 0.0.0.0 0.0.0.0 66.110.117.33 track 2
ip route 0.0.0.0 0.0.0.0 64.30.154.81 10 track 3
ip route 4.2.2.2 255.255.255.255 64.30.154.81 permanent
ip route 8.8.8.8 255.255.255.255 196.46.76.1 permanent
ip route 10.10.0.0 255.255.254.0 10.10.50.254
ip route 10.10.12.0 255.255.255.0 10.10.50.254
ip route 208.67.222.222 255.255.255.255 66.110.117.33 permanent
ip nat inside source route-map NAT-DIALER0 interface Dialer0 overload
ip access-list standard VISITORS_ACCESS
remark --- Access List to forward VISITORS traffic to SNET Line
permit 172.16.27.0 0.0.0.3
ip access-list extended NAT-ACL
permit ip 172.16.14.0 0.0.0.3 any
permit ip 172.16.60.0 0.0.0.3 any
permit ip 172.16.26.0 0.0.0.3 any
permit ip 172.16.27.0 0.0.0.3 any
route-map VISITORS_POLICY_ROUTE permit 10
match ip address VISITORS_ACCESS
set ip next-hop 196.46.76.1
route-map NAT-DIALER0 permit 10
match ip address NAT-ACL
match interface Dialer0
route-map NAT-FASTETHERNET1 permit 10
match interface FastEthernet1
route-map NAT-VLAN31 permit 10
match interface Vlan31
5 Replies 5
David Salazar
Hi, Alcides.
Is the route-map doing the job for the Guests access to Web Access?
Is the answer is yes.
You only need to create a route-map that match the email traffic from Vlan of LAN Users and set the ip next-hop to the 2 link.
Example:
ip access-list ext EMAIL_TRAFFIC
permit tcp any any eq 25
route-map INTERNAL_USERS_EMAIL permit 10
match ip address EMAIL_TRAFFIC
set ip next-hop Y.Y.Y.Y (IP of 2 link next hop)
interface VLAN YY
description *** VLAN_INSIDE_USERS ***
ip address .Z.Z.Z.Z W.W.W.W
ip nat inside
ip policy route-map INTERNAL_USERS_EMAIL
hope that help you.
DS
Hi David,
thanks for your quickly response... this is the big deal! the first question is where my problem reside for now... so the answer is no.
Hi, Alcides.
Was you used the debug ip policy command? If not, can you use it?
The following link is so useful:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml  (Undestanding Policy Routing)
can you show me the output of show route-map command?
Can you show me the output of show ip access-list VISITORS_ACCESS?
Is posible to change the standard access-list to a extend access-list more specify:
to
ip access-list extended VISITORS_ACCESS
permit tcp 172.16.27.0 0.0.0.3 0.0.0.0 0.0.0.0 eq 80 443
A question if you are modified the next-hop to all traffic, who resolve the DNS request? are you try to access a web site using the ip address directly?
I hope help you.
Hi, David
R: i want to all traffic from this network(VISITORS) get routed to Dailer0, all traffic since dns to http
thks for your attention
output below
CUCALDA_N1_RTBorder#show route-map
route-map VISITORS_POLICY_ROUTE, permit, sequence 10
  Match clauses:
    ip address (access-lists): VISITORS_ACCESS
  Set clauses:
    ip next-hop verify-availability 196.46.76.1 10 track 1  [up]
  Policy routing matches: 6413 packets, 547372 bytes
route-map NAT-DIALER0, permit, sequence 10
  Match clauses:
    ip address (access-lists): NAT-ACL
    interface Dialer0
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
route-map NAT-FASTETHERNET1, permit, sequence 10
  Match clauses:
  Set clauses:
route-map NAT-VLAN31, permit, sequence 10
  Match clauses:
    interface Vlan31
  Set clauses:
CUCALDA_N1_RTBorder#show ip access-list VISITORS_ACCESS
Standard IP access list VISITORS_ACCESS
    10 permit 172.16.27.0, wildcard bits 0.0.0.3 (18136 matches)
    10 permit 172.16.27.0, wildcard bits 0.0.0.3 (18394 matches)
CUCALDA_N1_RTBorder#debug ip policy
Policy routing debugging is on
*Apr  4 11:40:43.310 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, FIB policy match
*Apr  4 11:40:43.310 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:43.310 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 65, FIB policy match
*Apr  4 11:40:43.310 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:43.310 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, policy match
*Apr  4 11:40:43.310 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:43.310 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 65, policy routed
*Apr  4 11:40:43.310 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:43.310 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 65, policy match
*Apr  4 11:40:43.310 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4 (Dialer0), len 65, policy routed
*Apr  4 11:40:43.514 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, FIB policy match
*Apr  4 11:40:43.514 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:43.514 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, policy match
*Apr  4 11:40:43.514 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:43.514 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 65, policy routed
*Apr  4 11:40:43.514 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:43.514 GMT: %FW-6-SESS_AUDIT_TRAIL_START: Start udp session: initiator (172.16.27.2:53581) -- responder (208.67.220.220:53)
*Apr  4 11:40:44.510 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 65, FIB policy match
*Apr  4 11:40:44.510 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:44.510 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 65, policy match
*Apr  4 11:40:44.510 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:44.514 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4 (Dialer0), len 65, policy routed
*Apr  4 11:40:44.514 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:44.514 GMT: %FW-6-SESS_AUDIT_TRAIL_START: Start udp session: initiator (172.16.27.2:53581) -- responder (8.8.4.4:53)
*Apr  4 11:40:45.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, FIB policy match
*Apr  4 11:40:45.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:45.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, policy match
*Apr  4 11:40:45.510 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:45.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 65, policy routed
*Apr  4 11:40:45.514 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:47.334 GMT: %FW-6-SESS_AUDIT_TRAIL: Stop udp session: initiator (172.16.27.2:61211) sent 135 bytes -- responder (8.8.4.4:53) sent 0 bytes
*Apr  4 11:40:47.334 GMT: %FW-6-SESS_AUDIT_TRAIL: Stop udp session: initiator (172.16.27.2:61211) sent 180 bytes -- responder (208.67.220.220:53) sent 0 bytes
*Apr  4 11:40:47.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, FIB policy match
*Apr  4 11:40:47.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:47.510 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 65, FIB policy match
*Apr  4 11:40:47.510 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:47.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, policy match
*Apr  4 11:40:47.514 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:47.514 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 65, policy routed
*Apr  4 11:40:47.514 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:47.514 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 65, policy match
*Apr  4 11:40:47.514 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4 (Dialer0), len 65, policy routed
*Apr  4 11:40:50.406 GMT: %FW-6-SESS_AUDIT_TRAIL: Stop udp session: initiator (172.16.27.2:65444) sent 148 bytes -- responder (208.67.220.220:53) sent 0 bytes
*Apr  4 11:40:50.406 GMT: %FW-6-SESS_AUDIT_TRAIL: Stop udp session: initiator (172.16.27.2:65444) sent 111 bytes -- responder (8.8.4.4:53) sent 0 bytes
*Apr  4 11:40:51.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, FIB policy match
*Apr  4 11:40:51.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:51.510 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 65, FIB policy match
*Apr  4 11:40:51.510 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, g=196.46.76.1, len 65, FIB policy routed
*Apr  4 11:40:51.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 65, policy match
*Apr  4 11:40:51.510 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:51.510 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 65, policy routed
*Apr  4 11:40:51.514 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:51.514 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 65, policy match
*Apr  4 11:40:51.514 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:51.514 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4 (Dialer0), len 65, policy routed
*Apr  4 11:40:51.686 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 68, FIB policy match
*Apr  4 11:40:51.686 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 68, FIB policy routed
*Apr  4 11:40:51.686 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 68, policy match
*Apr  4 11:40:51.686 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:51.686 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 68, policy routed
*Apr  4 11:40:51.686 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:51.686 GMT: %FW-6-SESS_AUDIT_TRAIL_START: Start udp session: initiator (172.16.27.2:63528) -- responder (208.67.220.220:53)
*Apr  4 11:40:52.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 68, FIB policy match
*Apr  4 11:40:52.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, g=196.46.76.1, len 68, FIB policy routed
*Apr  4 11:40:52.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 68, policy match
*Apr  4 11:40:52.682 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:52.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4 (Dialer0), len 68, policy routed
*Apr  4 11:40:52.682 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:52.682 GMT: %FW-6-SESS_AUDIT_TRAIL_START: Start udp session: initiator (172.16.27.2:63528) -- responder (8.8.4.4:53)
*Apr  4 11:40:53.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 68, FIB policy match
*Apr  4 11:40:53.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 68, FIB policy routed
*Apr  4 11:40:53.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 68, policy match
*Apr  4 11:40:53.682 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:53.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 68, policy routed
*Apr  4 11:40:53.682 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:55.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 68, FIB policy match
*Apr  4 11:40:55.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 68, FIB policy routed
*Apr  4 11:40:55.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 68, FIB policy match
*Apr  4 11:40:55.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, g=196.46.76.1, len 68, FIB policy routed
*Apr  4 11:40:55.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 68, policy match
*Apr  4 11:40:55.682 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:55.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 68, policy routed
*Apr  4 11:40:55.682 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:55.686 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 68, policy match
*Apr  4 11:40:55.686 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:55.686 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4 (Dialer0), len 68, policy routed
*Apr  4 11:40:55.686 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:56.038 GMT: %FW-6-SESS_AUDIT_TRAIL: Stop udp session: initiator (172.16.27.2:137) sent 150 bytes -- responder (172.16.27.3:137) sent 0 bytes
*Apr  4 11:40:58.598 GMT: %FW-6-SESS_AUDIT_TRAIL: Stop udp session: initiator (172.16.27.2:53581) sent 148 bytes -- responder (208.67.220.220:53) sent 0 bytes
*Apr  4 11:40:58.598 GMT: %FW-6-SESS_AUDIT_TRAIL: Stop udp session: initiator (172.16.27.2:53581) sent 111 bytes -- responder (8.8.4.4:53) sent 0 bytes
*Apr  4 11:40:59.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 68, FIB policy match
*Apr  4 11:40:59.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 68, FIB policy routed
*Apr  4 11:40:59.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 68, FIB policy match
*Apr  4 11:40:59.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, g=196.46.76.1, len 68, FIB policy routed
*Apr  4 11:40:59.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 68, policy match
*Apr  4 11:40:59.682 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:59.682 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 68, policy routed
*Apr  4 11:40:59.682 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:40:59.682 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 68, policy match
*Apr  4 11:40:59.686 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:40:59.686 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4 (Dialer0), len 68, policy routed
*Apr  4 11:40:59.686 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:41:02.074 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 73, FIB policy match
*Apr  4 11:41:02.078 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, g=196.46.76.1, len 73, FIB policy routed
*Apr  4 11:41:02.078 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220, len 73, policy match
*Apr  4 11:41:02.078 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:41:02.078 GMT: IP: s=172.16.27.2 (Vlan27), d=208.67.220.220 (Dialer0), len 73, policy routed
*Apr  4 11:41:02.078 GMT: IP: Vlan27 to Dialer0 196.46.76.1
*Apr  4 11:41:02.078 GMT: %FW-6-SESS_AUDIT_TRAIL_START: Start udp session: initiator (172.16.27.2:51885) -- responder (208.67.220.220:53)
*Apr  4 11:41:03.074 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 73, FIB policy match
*Apr  4 11:41:03.074 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, g=196.46.76.1, len 73, FIB policy routed
*Apr  4 11:41:03.074 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4, len 73, policy match
*Apr  4 11:41:03.074 GMT: IP: route map VISITORS_POLICY_ROUTE, item 10, permit
*Apr  4 11:41:03.074 GMT: IP: s=172.16.27.2 (Vlan27), d=8.8.4.4 (Dialer0), len 73, policy routed
*Apr  4 11:41:03.074 GMT: IP: Vlan27 to Dialer0 196.46.76.1
Alcides Miguel
Thanks you all for your attention finally i found the solution using vrf feature
