Problem with T1 card configuration
Colin Higgins
Level 2
Level 2
I have a 2851 router with a T1/E1 HWIC card installed in slot 0
I am attempting to configure a simple T1, but the system is not letting me configure the serial interface
this is the config I have so far :
card type t1 0 0
no network-clock-participate wic 0
no network-clock-participate aim 0
controller T1 0/0/0
framing esf
linecode b8zs
cablelength short 133
channel-group 1 timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
channel-group 2 timeslots 1-24
and interfaces
Serial0/0/0:1              unassigned      YES unset  down                  down
Serial0/0/1:2              unassigned      YES unset  down                  down
show up, but I can't get into them.
01-P1-2851_Voice(config)#int Serial ?
  <0-2>  Serial interface number
01-P1-2851_Voice(config)#int Serial 0 ?
% Unrecognized command
01-P1-2851_Voice(config)#int Serial 0/0/0:1
% Invalid input detected at '^' marker.
something I am missing?
try and add the following (in bold) to your controllers:
controller T1 0/0/1
framing esf
linecode b8zs
fdl both
clock source line
channel-group 2 timeslots 1-24 speed 64
crc-threshold 500
Also, can you post the output of 'show version' ?
controller T1 0/0/1
framing esf
linecode b8zs
fdl both
clock source line
crc-threshold 500
I discovered that you have to start with channel-group 0 which produces interface Serial 0/0/0:0
for some reason, it won't accept starting with channel-group 1
Colin,
honestly I have not seen that documented ever, anywhere. Good that you found out !
