Problems getting connection over isdn
mannischmidt
I am trying to connect via isdn to other routers. But i can't connect to a special one until the other router builds a connection to me. After that I can get ftp eg.
In my config I have different dialer for each host I am trying to connect every dialer looks the same:
interface Dialer123
description *Connection to 123
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer remote-name D123
dialer idle-timeout 180
dialer string 0123456789
dialer caller 123456789
dialer-group 1
no snmp trap link-status
no cdp enable
starting debugging gives me following during ping the other side:
router01#
Mar  8 11:31:50.945: %SEC-6-IPACCESSLOGDP: list 199 permitted icmp 192.168.0.2 -> 192.168.1.34 (0/0), 1 packet
router01#
Mar  8 11:31:50.953: ISDN Se1/0:15: TX -> SETUP pd = 8  callref = 0x3D85
Mar  8 11:31:50.953:         Bearer Capability i = 0x8890
Mar  8 11:31:50.953:         Channel ID i = 0xA9839F
Mar  8 11:31:50.953:         Called Party Number i = 0x81, '0123456789', Plan:ISDN, Type:Unknown
Mar  8 11:31:50.985: ISDN Se1/0:15: RX <- SETUP_ACK pd = 8  callref = 0xBD85
Mar  8 11:31:50.989:         Channel ID i = 0xA9839F
router01#
Mar  8 11:31:53.453: ISDN Se1/0:15: RX <- CALL_PROC pd = 8  callref = 0xBD85
Mar  8 11:31:53.505: ISDN Se1/0:15: RX <- CONNECT pd = 8  callref = 0xBD85
Mar  8 11:31:53.505:         Date/Time i = 0x0D03080B1F34
Mar  8 11:31:53.541: %LINK-3-UPDOWN: Interface Serial1/0:30, changed state to up
Mar  8 11:31:53.545: %DIALER-6-BIND: Interface Se1/0:30 bound to profile Di123
router01#
Mar  8 11:31:53.549: ISDN Se1/0:15: TX -> CONNECT_ACK pd = 8  callref = 0x3D85
router01#
Mar  8 11:31:59.545: %ISDN-6-CONNECT: Interface Serial1/0:30 is now connected to 0123456789
router01#
Mar  8 11:32:13.546: %ISDN-6-DISCONNECT: Interface Serial1/0:30  disconnected from 0123456789 , call lasted 20 seconds
Mar  8 11:32:13.546: ISDN Se1/0:15: TX -> DISCONNECT pd = 8  callref = 0x3D85
Mar  8 11:32:13.550:         Cause i = 0x8090 - Normal call clearing
Mar  8 11:32:13.574: ISDN Se1/0:15: RX <- RELEASE pd = 8  callref = 0xBD85
Mar  8 11:32:13.626: %LINK-3-UPDOWN: Interface Serial1/0:30, changed state to down
Mar  8 11:32:13.626: %DIALER-6-UNBIND: Interface Se1/0:30 unbound from profile D123
router01#
Mar  8 11:32:13.630: ISDN Se1/0:15: TX -> RELEASE_COMP pd = 8  callref = 0x3D85
Mar  8 11:32:13.802: ISDN Se1/0:15: TX -> SETUP pd = 8  callref = 0x3D86
Mar  8 11:32:13.802:         Bearer Capability i = 0x8890
Mar  8 11:32:13.802:         Channel ID i = 0xA9839F
Mar  8 11:32:13.806:         Called Party Number i = 0x81, '0123456789', Plan:ISDN, Type:Unknown
Mar  8 11:32:13.846: ISDN Se1/0:15: RX <- SETUP_ACK pd = 8  callref = 0xBD86
Mar  8 11:32:13.846:         Channel ID i = 0xA9839F
router01#
Mar  8 11:32:16.306: ISDN Se1/0:15: RX <- CALL_PROC pd = 8  callref = 0xBD86
Mar  8 11:32:16.342: ISDN Se1/0:15: RX <- CONNECT pd = 8  callref = 0xBD86
Mar  8 11:32:16.342:         Date/Time i = 0x0D03080B200F
Mar  8 11:32:16.382: %LINK-3-UPDOWN: Interface Serial1/0:30, changed state to up
Mar  8 11:32:16.382: %DIALER-6-BIND: Interface Se1/0:30 bound to profile Di123
router01#
Mar  8 11:32:16.386: ISDN Se1/0:15: TX -> CONNECT_ACK pd = 8  callref = 0x3D86
Mar  8 11:32:17.534: ISDN Se1/0:15: RX <- SETUP pd = 8  callref = 0x00F4
Mar  8 11:32:17.538:         Bearer Capability i = 0x8890
Mar  8 11:32:17.538:         Channel ID i = 0xA98385
Mar  8 11:32:17.538:         Facility i = 0x91A1280202008002010F301F0201010A0100A117A015A1130A0100120E3038303133303732363139303030
Mar  8 11:32:17.542:    - ETSI Supplementary Service, Invoke, Diverting leg 2
Mar  8 11:32:17.542:         Date/Time i = 0x0D03080B2010
Mar  8 11:32:17.542:         Calling Party Number i = 0x01, 0x81, '0123456789', Plan:ISDN, Type:Unknown
Mar  8 11:32:17.546:         Called Party Number i = 0xA1, 'mynumberwithoutzero', Plan:ISDN, Type:National
Mar  8 11:32:17.586: %ISDN-6-CONNECT: Interface Serial1/0:30 is now connected to 0123456789
router01#
Mar  8 11:32:17.590: ISDN Se1/0:15: TX -> CALL_PROC pd = 8  callref = 0x80F4
Mar  8 11:32:17.590:         Channel ID i = 0xA98385
Mar  8 11:32:17.594: ISDN Se1/0:15: TX -> CONNECT pd = 8  callref = 0x80F4
Mar  8 11:32:17.594:         Channel ID i = 0xA98385
Mar  8 11:32:17.594:         Facility i = 0x91A10A02020081020113010101
Mar  8 11:32:17.598:    - ETSI Supplementary Service, Invoke, Diverting leg 3
Mar  8 11:32:17.626: ISDN Se1/0:15: RX <- CONNECT_ACK pd = 8  callref = 0x00F4
Mar  8 11:32:17.630: ISDN Se1/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x6F83, bchan 4, dsl 0
router01#
Mar  8 11:32:24.787: ISDN Se1/0:15: RX <- SETUP_ACK pd = 8  callref = 0xBD87
Mar  8 11:32:24.787:         Channel ID i = 0xA9839E
router01#
I am not really familiar with ISDN, but I think there is missing the RX<-ALERT...
please anybody can help me??!!
5 Replies 5
anisaini
Hi Manfred,
From the logs you can see that call lasts for 20 sec so there doesnt sem to be any issues with the call setup as there is a cal which lasts 20 secs and disconnects as normal call clearing.
so if this is the call you are interrested in then you probably need to check with the telco so as to why exactly this call lasts for 20 secs and not beyond(180 is the diel timer configured)
Setup exchnage:
connect exchange:
router01#
successful connet:
disconnects:
if your issue is not what i understood please initiate a call and capture the following debugs
debug isdn q931
debug isdn q921
debug isdn error
debug isdn eve
debug dialer
sh isdn ac...while call is active
sh isdn st...while cal is active
As i again said if the call disconnectsafter 20 secs it is most likely telco issue,ask teclo to route the same call via  different local switch in their infrastructure.
I do not see in the config any dialer-list or anything else that would identify "interesting" traffic. Is there something that I missed?
Rick
Rick
Hello Anil,
thanks for the fast answer. I tried to get the informations and first´the monitor log:
router01#term mon
router01#
router01#
Mar 11 09:53:24.678: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0xFE64 CALL_PROGRESS
Mar 11 09:53:24.682: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=105
Mar 11 09:53:24.682: ISDN Se1/0:15: TX -> INFOc sapi=0 tei=0 ns=19 nr=105 i=0x080245B70F
Mar 11 09:53:24.682:     CONNECT_ACK pd = 8  callref = 0x45B7
Mar 11 09:53:24.690: ISDN Se1/0:15: RX <- RRr sapi=0 tei=0 nr=20
router01#
Mar 11 09:53:28.679: Se1/0:15 DDR: rotor dialout [priority]
Mar 11 09:53:28.679: Se1/0:15 DDR: Dialing cause ip (s=192.168.0.2, d=192.168.1.34)
Mar 11 09:53:28.679: Se1/0:15 DDR: Attempting to dial 0123456789
Mar 11 09:53:28.679: ISDN Se1/0:15: Outgoing call id = 0xFE65, dsl 0
Mar 11 09:53:28.683: ISDN Se1/0:15: Event: Call to 0123456789 at 64 Kb/s
Mar 11 09:53:28.683: ISDN Se1/0:15: process_pri_call(): call id 0xFE65, number 0123456789, speed 64, call type DATA, redialed? f, csm call? f, pdata? f
Mar 11 09:53:28.683: callED type/plan overridden by call_decode
Mar 11 09:53:28.683: did't copy oct3a reason: not CALLER_NUMBER_IE
Mar 11 09:53:28.683:  building outgoing channel id for call nfas_int is 0 len is 0
Mar 11 09:53:28.687: ISDN Se1/0:15: TX -> INFOc sapi=0 tei=0 ns=20 nr=105 i=0x080245B805040288901803A9839E700D81303231313539383232333833
Mar 11 09:53:28.691:     SETUP pd = 8  callref = 0x45B8
Mar 11 09:53:28.691:         Bearer Capability i = 0x8890
Mar 11 09:53:28.691:         Channel ID i = 0xA9839E
Mar 11 09:53:28.691:         Called Party Number i = 0x81, '0123456789', Plan:ISDN, Type:Unknown
Mar 11 09:53:28.703: ISDN Se1/0:15: RX <- RRr sapi=0 tei=0 nr=21
Mar 11 09:53:28.723: ISDN Se1/0:15: RX <- INFOc sapi=0 tei=0 ns=105 nr=21 i=0x0802C5B80D1803A9839E
router01#SETUP_ACK pd = 8  callref = 0xC5B8
Mar 11 09:53:28.727:         Channel ID i = 0xA9839E
Mar 11 09:53:28.727: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=106
Mar 11 09:53:28.731: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0xFE65 CALL_SETUP_ACK
Mar 11 09:53:28.731: ISDN Se1/0:15: PRI Event: 16, bchan = 29, call type = DATA
router01#
Mar 11 09:53:31.192: ISDN Se1/0:15: RX <- INFOc sapi=0 tei=0 ns=106 nr=21 i=0x0802C5B802
Mar 11 09:53:31.192:     CALL_PROC pd = 8  callref = 0xC5B8
Mar 11 09:53:31.192: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=107
Mar 11 09:53:31.196: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0xFE65 CALL_PROCEEDING
Mar 11 09:53:31.232: ISDN Se1/0:15: RX <- INFOc sapi=0 tei=0 ns=107 nr=21 i=0x0802C5B80729060D030B09351F
Mar 11 09:53:31.232:     CONNECT pd = 8  callref = 0xC5B8
Mar 11 09:53:31.232:         Date/Time i = 0x0D030B09351F
Mar 11 09:53:31.236: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=108
Mar 11 09:53:31.236: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0xFE65 CALL_CONNECT
Mar 11 09:53:31.272: %LINK-3-UPDOWN: Interface Serial1/0:29, changed state to up
Mar 11 09:53:31.272: Se1/0:29: interface must be fifo queue, force fifo
Mar 11 09:53:31.276: %DIALER-6-BIND: Interface Se1/0:29 bound to profile Di123
router01#
Mar 11 09:53:31.280: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0xFE65 CALL_PROGRESS
Mar 11 09:53:31.280: ISDN Se1/0:15: TX -> INFOc sapi=0 tei=0 ns=21 nr=108 i=0x080245B80F
Mar 11 09:53:31.280:     CONNECT_ACK pd = 8  callref = 0x45B8
Mar 11 09:53:31.288: ISDN Se1/0:15: RX <- RRr sapi=0 tei=0 nr=22
router01#
Mar 11 09:53:37.278: %ISDN-6-CONNECT: Interface Serial1/0:29 is now connected to 0123456789
router01#
Mar 11 09:53:39.911: %SEC-6-IPACCESSLOGP: list 199 permitted udp 192.168.66.30(0) -> 192.168.66.255(0), 4 packets
Mar 11 09:53:39.963: ISDN Se1/0:15: RX <- INFOc sapi=0 tei=0 ns=108 nr=22 i=0x080200B44508028090
Mar 11 09:53:39.963:     DISCONNECT pd = 8  callref = 0x00B4
Mar 11 09:53:39.963:         Cause i = 0x8090 - Normal call clearing
Mar 11 09:53:39.967: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=109
Mar 11 09:53:40.183: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0x7C36 CALL_DISC
1Mar 11 09:53:40.235: Se1/0:15 DDR: has total 2 call(s), dial_out 2, dial_in 0
1Mar 11 09:53:40.239: ISDN Se1/0:15: process_disc_ack(): call id 0x7C36, ces 1, call type DATA cause 0x10
Mar 11 09:53:40.239: ISDN Se1/0:15: TX -> INFOc sapi=0 tei=0 ns=22 nr=109 i=0x080280B44D
Mar 11 09:53:40.239:     RELEASE pd = 8  callref = 0x80B4
Mar 11 09:53:40.267: ISDN Se1/0:15: RX <- RRr sapi=0 tei=0 nr=23
Mar 11 09:53:40.267: ISDN Se1/0:15: RX <- INFOc sapi=0 tei=0 ns=109 nr=23 i=0x080200B45A
Mar 11 09:53:40.267:     RELEASE_COMP pd = 8  callref = 0x00B4
Mar 11 09:53:40.271: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=110
Mar 11 09:53:40.275: ISDN Se1/0:15: CCPRI_ReleaseCall(): bchan 25, call id 0x7C36, call type DATA
router01#
Mar 11 09:53:40.275: CCPRI_ReleaseChan released b_dsl 0 B_Chan 25
Mar 11 09:53:40.275: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0x7C36 CALL_CLEARED
Mar 11 09:53:40.275: ISDN Se1/0:15: received CALL_CLEARED  call_id 0x7C36
Mar 11 09:53:40.275: no resend setup, no redial
router01#
Mar 11 09:53:44.689: ISDN Se1/0:15: Event: Hangup call to call id 0xFE64
Mar 11 09:53:44.689: ISDN Se1/0:15: process_disconnect(): call id 0xFE64, call type is DATA, b_idb 0x61475810, ces 1, cause Normal call clearing(0x10)
router01#
Mar 11 09:53:44.693: ISDN Se1/0:15: TX -> INFOc sapi=0 tei=0 ns=23 nr=110 i=0x080245B74508028090
Mar 11 09:53:44.693:     DISCONNECT pd = 8  callref = 0x45B7
Mar 11 09:53:44.693:         Cause i = 0x8090 - Normal call clearing
Mar 11 09:53:44.709: ISDN Se1/0:15: RX <- RRr sapi=0 tei=0 nr=24
Mar 11 09:53:44.725: ISDN Se1/0:15: RX <- INFOc sapi=0 tei=0 ns=110 nr=24 i=0x0802C5B74D
Mar 11 09:53:44.725:     RELEASE pd = 8  callref = 0xC5B7
Mar 11 09:53:44.729: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=111
Mar 11 09:53:44.729: ISDN Se1/0:15: CCPRI_ReleaseCall(): bchan 31, call id 0xFE64, call type DATA
Mar 11 09:53:44.729: CCPRI_ReleaseChan released b_dsl 0 B_Chan 31
Mar 11 09:53:44.733: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0xFE64 CALL_CLEARED
Mar 11 09:53:44.733: ISDN Se1/0:15: received CALL_CLEARED  call_id 0xFE64
Mar 11 09:53:44.733: no resend setup, no redial
Mar 11 09:53:44.781: Se1/0:15 DDR: has total 1 call(s), dial_out 1, dial_in 0
router01#
Mar 11 09:53:44.785: ISDN Se1/0:15: TX -> INFOc sapi=0 tei=0 ns=24 nr=111 i=0x080245B75A
Mar 11 09:53:44.785:     RELEASE_COMP pd = 8  callref = 0x45B7
Mar 11 09:53:44.801: ISDN Se1/0:15: RX <- RRr sapi=0 tei=0 nr=25
router01#
Mar 11 09:53:51.303: Se1/0:29 DDR: disconnecting call
Mar 11 09:53:51.303: ISDN Se1/0:15: Event: Hangup call to call id 0xFE65
Mar 11 09:53:51.303: ISDN Se1/0:15: process_disconnect(): call id 0xFE65, call type is DATA, b_idb 0x6146CA50, ces 1, cause Normal call clearing(0x10)
Mar 11 09:53:51.303: %ISDN-6-DISCONNECT: Interface Serial1/0:29  disconnected from 0123456789 , call lasted 20 seconds
Mar 11 09:53:51.307: ISDN Se1/0:15: TX -> INFOc sapi=0 tei=0 ns=26 nr=112 i=0x080245B84508028090
Mar 11 09:53:51.307:     DISCONNECT pd = 8  callref = 0x45B8
Mar 11 09:53:51.307:         Cause i = 0x8090 - Normal call clearing
Mar 11 09:53:51.319: ISDN Se1/0:15: RX <- RRr sapi=0 tei=0 nr=27
Mar 11 09:53:51.331: ISDN Se1/0:15: RX <- INFOc sapi=0 tei=0 ns=112 nr=27 i=0x0802C5B84D
Mar 11 09:53:51.331:     RELEASE pd = 8  callref = 0xC5B8
Mar 11 09:53:51.335: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=113
Mar 11 09:53:51.335: ISDN Se1/0:15: CCPRI_ReleaseCall(): bchan 30, call id 0xFE65, call type DATA
Mar 11 09:53:51.335: CCPRI_ReleaseChan released b_dsl 0 B_Chan 30
Mar 11 09:53:51.335: ISDN Se1/0:15: LIF_EVENT: ces/callid 1/0xFE65 CALL_CLEARED
Mar 11 09:53:51.335: ISDN Se1/0:15: received CALL_CLEARED  call_id 0xFE65
Mar 11 09:53:51.335: no resend setup, no redial
Mar 11 09:53:51.383: %LINK-3-UPDOWN: Interface Serial1/0:29, changed state to down
Mar 11 09:53:51.383: Se1/0:15 DDR: has total 1 call(s), dial_out 1, dial_in 0
Mar 11 09:53:51.387: Se1/0:29 DDR: disconnecting call
Mar 11 09:53:51.387: %DIALER-6-UNBIND: Interface Se1/0:29 unbound from profile Di123
Mar 11 09:53:51.391: ISDN Se1/0:15: TX -> INFOc sapi=0 tei=0 ns=27 nr=113 i=0x080245B85A
Mar 11 09:53:51.391:     RELEASE_COMP pd = 8  callref = 0x45B8
Mar 11 09:53:51.399: ISDN Se1/0:15: RX <- RRr sapi=0 tei=0 nr=28
Mar 11 09:53:51.731: ISDN Se1/0:15: RX <- INFOc sapi=0 tei=0 ns=113 nr=28 i=0x0802C5B902
Mar 11 09:53:51.731:     CALL_PROC pd = 8  callref = 0xC5B9
Mar 11 09:53:51.735: ISDN Se1/0:15: TX -> RRr sapi=0 tei=0 nr=114
router01#term no mon
after that i tried to get isdn active and isdn status. There wasn't active idsn calls to my destitation and I looked up the status three time during a ping:
router01#sh isdn act         st
Global ISDN Switchtype = primary-net5
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
ACTIVE
    Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
I_Queue_Len 0, UI_Queue_Len 0
    Layer 3 Status:
3 Active Layer 3 Call(s)
CCB:callid=FE67, sapi=0, ces=0, B-chan=31, calltype=DATA
CCB:callid=7C38, sapi=0, ces=0, B-chan=27, calltype=DATA
CCB:callid=FE68, sapi=0, ces=0, B-chan=30, calltype=DATA
    Active dsl 0 CCBs = 3
    The Free Channel Mask:  0x9BFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 3
router01#sh isdn st  act
    Layer 1 Status:
ACTIVE
    Layer 2 Status:
    Layer 3 Status:
2 Active Layer 3 Call(s)
CCB:callid=FE69, sapi=0, ces=0, B-chan=31, calltype=DATA
    Active dsl 0 CCBs = 2
    The Free Channel Mask:  0x9FFF7FFF
Total Allocated ISDN CCBs = 2
    Layer 1 Status:
ACTIVE
    Layer 2 Status:
    Layer 3 Status:
1 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 1
    The Free Channel Mask:  0xBFFF7FFF
    Total Allocated ISDN CCBs = 1
Maybe this will get any hint.
Kind Regards
Manni
Still some more information and show outputs are missing.
But going forward you can follow this.
1. test if the call gets disconnected after 20 sec for  only specific site, if yes then telco needs to trace the call path if  any issue on all in intermediate switches........(this site and remote  site
2. check if you can make calls to different site for more than 20sec, if yes then you can isolate the issue to remote site
, if all calls from this hub last for 20 secs then possible issue local to this hub site
still  with my experience more of a telco issue which you need some tests with  telco and asking them to change path and then again testing by making  calls from router and confirming.
hope this helps
thanks. I don't have this problem on every site. other sites connects faster than 20seconds.
here a snap of my config: the normal config includes more dialer and the ip routes for these:
Current configuration : 36041 bytes
! Last configuration change at 14:28:49 DST Wed Apr 3 2013 by nextnet
! NVRAM config last updated at 16:21:31 DST Tue Apr 2 2013 by nextnet
version 12.2
service timestamps log datetime msec localtime
service password-encryption
hostname router01
logging buffered 64000 debugging
enable secret 5 ****
enable password 7 ****
clock timezone CET 1
clock summer-time DST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip subnet-zero
no ip domain-lookup
isdn switch-type primary-net5
controller E1 1/0
pri-group timeslots 1-31
description ISDN: ****
interface FastEthernet0/0
description *FE0/0*
ip address 192.168.75.1 255.255.255.252 secondary
ip address 192.168.81.19 255.255.255.0 secondary
ip address 192.168.125.1 255.255.255.0
ip access-group 199 in
ip access-group 199 out
ip nat inside
speed 100
full-duplex
interface Serial1/0:15
description ***
no ip address
encapsulation ppp
dialer pool-member 1
dialer pool-member 2 max-link 2
dialer pool-member 3 max-link 4
isdn fast-rollover-delay 5
ppp multilink
interface Dialer1
description *DIALER1*
ip nat outside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer remote-name D001
dialer string 0987654321
dialer caller 987654321
dialer-group 1
no cdp enable
interface Dialer4
description *DIALER4*
ip nat outside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer remote-name D004
dialer-group 1
no cdp enable
ip nat inside source list 102 interface Dialer90 overload
ip classless
ip route 192.168.1.0 255.255.255.252 Dialer1
ip route 192.168.4.0 255.255.255.252 Dialer4
no ip http server
logging trap debugging
access-list 80 permit 192.168.125.2
access-list 80 permit 192.168.75.2
access-list 102 permit ip host 192.168.81.18 147.151.0.0 0.0.255.255
access-list 102 permit ip host 192.168.81.17 147.151.0.0 0.0.255.255
access-list 199 permit ip any any log
access-list 199 permit icmp any any log
dialer-list 1 protocol ip permit
banner motd ^C
router01
UNAUTHORISED ACCESS TO THIS SYSTEM COULD CONSTITUTE A CRIMINAL OFFENCE!
Welcome to 192.168.125.1
^C
line con 0
speed 115200
line aux 0
line vty 0 4
access-class 80 in
exec-timeout 60 0
logging synchronous
login local
escape-character 27
ntp clock-period 17180109
ntp peer 192.168.125.2
end
