Problems with links between ASR9006 and NCS 5001
jm-barreto
Greetings
We are upgrading our MPLS network to 100GB using ASR 9006 and NCS 5001. In the ASR 9006, we use CFP 100G 40KM, and in the NCS 5001 QSFP28, 100GB 40KM. But we are having input errors and CRC issues. These problems were not there when those same links were at 10 GB.
I know that physical problems mainly cause these problems. But I need help getting the field staff to understand that :).
The OSPF/MPLS configuration is straightforward and is standard throughout our network, so there are no configuration problems.
When I check for alarms using "sh pfm," I don't see any warnings. The fpd is up to date. There are no logs reporting problems on any of the line cards or ports. The only constant thing I see is that I have these problems between ASR9006 and NCS 500 (CFP and QSFP28).
Will there be any compatibility problem between these SFPs?
I have attached an image of the power values ​​of the fiber and link distances.
0 Replies 0
