Propogate the Default Route
Ryan Wolf
Hey all,
I'm preparing to test out of a few entry-level CCNA courses at my College, and I'm having trouble having the routers on my network recognize the default route I set, when I tried to distribute it using the
 default-information originate
command. I've attached my PT file below, if someone could offer some guidance, that would be great.
https://drive.google.com/file/d/1LTM9TSCpTUMv-TKZuRB4WwWfENgeANCy/view?usp=drive_link
Defualt information originate
always
Try add always
5 Replies 5
Hello
Can you share the PT file here please instead of provding a link to it.
Kind Regards
Paul
Martin L
using the
default-information originate command, default route
must be present in routing table; show ip route and show run | section router
note that not all commands work in PT but
command should  be fine for RIP and OSPF in PT
Google says "You need access Request access, or switch to an account with access.
Make you file public access or attach PT file here "in a zip format a must be"
Regards, ML
**Please Rate All Helpful Responses **
always
Try add always
Ryan Wolf
Apologies, I forgot to change the link permissions. I would just send the PT file, but .pkt file types are not allowed to be added as an attachment. Sorry for the inconvenience.
https://drive.google.com/file/d/1LTM9TSCpTUMv-TKZuRB4WwWfENgeANCy/view?usp=sharing
Ryan Wolf
Actually, I checked my network today and it seems that the default route got shared with my branch routers. Seems I set it up correctly the first time, but it just needed a couple minutes to receive it? Well, at least it works. Thank you for the help.
