Pseudowire Redundancy with backup peer
sebastien3
Level 4
Level 4
I want to use the backup peer function with Xconnect (I tested on 892FSP, 921, ASR1001).
I realize that the command is not available even with a pw-class in L2TPv2 and L2TPv3 or MPLS.
LAB-01(config-if)#backup ?
  active     Configure an interface as an active backup
  delay      Delays before backup line up or down transitions
  interface  Configure an interface as a backup
  load       Load thresholds for line up or down transitions
Can you tell me how to use backup peer in the following way ?
pseudowire-class mpls-class
 encapsulation mpls
 interworking ethernet
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
xconnect 10.0.0.1 12345 encapsulation mpls pw-class mpls-class
backup peer 10.0.0.1 67890 pw-class mpls-class
backup delay 5 never
 Thanks for your help !
sebastien3
Level 4
Level 4
No idea ?
I think not all platform have this command,
instead you can use LO under psudo class  and make readability to other Peer via two path.
MHM
