QOS Bandwidth limitation Not working
MohammadSalih
hi every one ,
i have more than vlan and i have 100 mbps internet access ,
i want to divide the 100mbps on my vlans .
i do QOS command and it doesn't work , i have 2951 router
the command is :
access-list 110 permit ip  192.168.110.0 0.0.0.255 any
access-list 120 permit ip  192.168.120.0 0.0.0.255 any
 class-map match-all 110
match access-group 110
class-map match-all 120
match access-group 120
policy-map BAND
  class 110
    police 20000000 conform-action transmit exceed-action drop
  class 120
interface GigabitEthernet0/1
service-policy input BAND
service-policy output BAND
________________
this is the show version
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 19:11 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
UCIDN-NOC-RT uptime is 11 weeks, 5 days, 21 minutes
System restarted at 08:44:07 UTC Sat Mar 26 2022
System image file is "flash0:c2951-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 472064K/52224K bytes of memory.
Processor board ID FGL202510F3
7 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2951/K9 FGL202510F3
Technology Package License Information for Module:'c2951'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
13 Replies 13
balaji.bandi
I have done some test way back check below config may help you :
https://www.balajibandi.com/?p=1606
BB
thanks for replying still not working,
Can you post  updated config  ?
BB
when i write the command
#sh policy-map interface gigabitEthernet 0/1
GigabitEthernet0/1
Service-policy input: limit
Class-map: 120 (match-all)
16165 packets, 3345584 bytes
5 minute offered rate 56000 bps, drop rate 10000 bps
Match: access-group 120
police:
cir 2000000 bps, bc 62500 bytes
conformed 14983 packets, 2773433 bytes; actions:
transmit
exceeded 1182 packets, 572151 bytes; actions:
drop
conformed 387000 bps, exceed 68000 bps
Class-map: class-default (match-any)
9722 packets, 1715733 bytes
5 minute offered rate 28000 bps, drop rate 0 bps
Match: any
Service-policy output: limit
5 packets, 370 bytes
5 minute offered rate 0 bps, drop rate 0 bps
police:
conformed 5 packets, 370 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps
2259731 packets, 2733676456 bytes
5 minute offered rate 44111000 bps, drop rate 0 bps
int shows that only input work (upload)
the output didn't work (Download)
it shows that only input work (upload)
Hello
The service policy is only apllicable for ingress traffic into the vlan
Kind Regards
Paul
Hello
The service is only apllicable for ingress traffic into the vlan
is there any other way to limit output bandwidth for subnets ?
as per my testing and understanding -
Policy maps can be configured on ingress or egress devices
BB
in my case only the ingress is work
the egress not work ,
my device is 2951 is there any problem with this series or there are problem with the ios ?
That is the Limitation, most case we intiate the traffic from Lan, if any traffic coming from outside you can apply on outside interface.
BB
Hello
Append the vlan to the class map related to polucy map applied to the interface.
match vlan 110
match vlan 120
int x/x
Kind Regards
Paul
GigabitEthernet0/1
police:
transmit
drop
Match: any
police:
transmit
drop
Joseph W. Doherty
BTW, regarding why "in" policy appears to work but "out" policy doesn't, might be because you're using the same policy in both directions using underlying ACLs, that would only correctly work in one direction.
Try:
access-list 110 permit ip any 192.168.110.0 0.0.0.255
access-list 120 permit ip any 192.168.120.0 0.0.0.255
Also BTW, although an ingress policer will limit bandwidth to your inside hosts, it cannot truly limit ingress bandwidth usage because its downsteam of your Internet link.
