Qos configuration for 3945 Router for Voice Priority
Jim Matuska
What is the current recommended configuration on a 3945 Router to prioritize voice for Cisco IP Phones over data?  We used to just use auto qos on our older routers which worked quite well but it looks like this is no longer available on these routers and the 15.2T IOS.
What is the best/recommended way to make sure that my voice traffic takes priority over other traffic such as normal web browsing and such?
Jim
Dennis Mink
https://www.cisco.com/c/en/us/td/docs/routers/access/800M/software/800MSCG/QoS.html   is probably the best starting point,
if you trust the phones settings from the access ports they are connected to, you can just do a match on ef, af41 and 42.
on top of that use an accesslist to define RTP, port 5060/61 to set the dscp values to ef and af41 respectively.
cheers
Please remember to rate useful posts, by clicking on the stars below.
Francesco Molino
If you have Cisco IP phones with video capabilities you'll probably have ef and af41 traffic.
A quick example below, but make sure you'll consider everything before applying this basic qos configuration.
class-map match-any CMAP_VOICE
match dscp ef
class-map match-any CMAP_VIDEO
 match dscp af41
policy-map QOS_EXAMPLE
class CMAP_VOICE
  priority level 1
  police cir percent 10
class CMAP_VIDEO
  priority level 2
  police cir percent 20
class class-default
  fair-queue
  random-detect
This will imply that traffic is trusted on the LAN. If there's no making, you can replace the match dscp by match access-grouo using acl for example.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
