QoS configuration for DMVPN hub
rasmus.elmholt
Level 7
Level 7
I am trying to understand how to configure QoS on a DMVPN setup.
I have created some policy-maps the QoS configuration but for some reason I am unable to configure them on the tunnel interface. I have read the documentation but it seems like the configuration is not available on my router.
Per-Tunnel QoS for DMVPN
This is the tunnel configuration for the Hub:
interface Tunnel11111
 description DMVPN1
 vrf forwarding Internal
 ip address 10.0.11.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp network-id 11111
 ip tcp adjust-mss 1360
 tunnel source Loopback1
 tunnel mode gre multipoint
 tunnel key 11111
 tunnel vrf Internet
 tunnel protection ipsec profile L2L-VPN-IKV2 shared
R1(config-if)#ip nhrp map ?
  A.B.C.D    IP address of destination
  multicast  Use this NBMA mapping for broadcasts/multicasts
R1(config-if)#service-policy ?
  type  Configure CPL Service Policy
 I can't figure out if this is the software that does not support it, or if I have forgotten some configuration to enable it.
Cisco IOS XE Software, Version 16.12.05
  1. nhrp map group group-name service-policy output qos-policy-map-name <<- use command without start with ""ip""
Dynamic Multipoint VPN Configuration Guide, Cisco IOS XE Gibraltar 16.10.x - Per-Tunnel QoS for DMVPN [Cisco IOS XE 16] - Cisco
MHM
I get the issue let me check it
MHM
MHM
