No Auto Summary Not Saved in 3650_24PS
drushka
In Packet Tracer, I’m using a Layer 3 switch (3650_24PS) with OSPF configured. When I enter the command no auto-summary and save the configuration using either write memory or copy running-config startup-config, the setting is lost after a restart of Packet Tracer. The no auto-summary command is deleted upon reboot. Please Help
Thank you!
drushka
sorry meant eigrp making new post
It not delete
It run by defualt that why it not appear
Try use
Show run all
To see this command and othet defualt command
MHM
@drushka
 There is no "no auto-summary" command on 3650 in PacketTracer. You can see this command in EIGRP.
Those are the options.
area OSPF area parameters
auto-cost Calculate OSPF interface cost according to bandwidth
default-information Control distribution of default information
distance Define an administrative distance
exit Exit from routing protocol configuration mode
log-adjacency-changes Log changes in adjacency state
neighbor Specify a neighbor router
network Enable routing on an IP network
no Negate a command or set its defaults
passive-interface Suppress routing updates on an interface
redistribute Redistribute information from another routing protocol
router-id router-id for this OSPF process
drushka
