Qos configuration with Rate-limit
ravichandrantg
I have currently configured priority queuing with high,medium,low and normal criteria matching accesslist on my serial interface connecting a remote site.
The current bandwidth on the serial LL is 1 Mbps, i would like to reduce the same to 512 Kbps.
In order to test that i would like to configure the interface with rate-limit.
If i apply rate-limit on the Serial interface for 512 Kbps whether priority queing will be effected after the traffic reaches 512 Kbps.
Please clarify.
Ravi
royalblues
Level 10
Level 10
You should actually use a nested policy map, wherein the overall bandwidth is policed or shaped as per your needs
eg.
policy-map WAN-child
class VOICE
priority percent 20
policy-map WAN-parent-policy
class class-default
shape average 512000 ---- you can also police
service-policy WAN-child
This would ensure your overall CAR still respecting priority for LLQ
HTH, rate if it does
Narayan
royalblues
Level 10
Level 10
eg.
class VOICE
priority percent 20
class class-default
Narayan
mheusing
Assuming your router does support it, hierarchical QoS policies would be exactly what you need. One policy is used to shape the rate down to a configurable rate and the second poicy would then prioritize traffic within the defined bandwidth.
Example:
class-map match-all Mytraffic1
match ip address 101
! specify ACL 101 to match traffic for priority queue
class-map match-all Mytraffic2
match ip address 102
! specify ACL 102 to match other important traffic
policy-map Shape512k
class class-default
service-policy output Prio
policy-map Prio
class Mytraffic1
priority 128
class MyTraffic2
bandwidth 200
class class-default
fair-queue
random-detect
Interface Serial0
bandwidth 512
ip address 10.1.1.1 255.255.255.252
service-policy output shape512k
You have to adjust the example config to your environment and also could use many more classes than depicted.
In case you add a "rate-limit" command to the interface per class, you would drop traffic, if it increases above the specified rate, regardless of the available capacity at this moment. In the above config MytrafficX will get minimum guarantees and thus might be allowed to get the full shaped bandwidth, if no other traffic is present.
The example above follows current best practice. For further reading have a look at "Enterprise QoS Solution Reference Network Design Guide Version 3.3"
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Hope this helps! Please rate all posts.
Regards, Martin
Thanks , this exactly match my requirement
