QoS for Voice Example
Filip Knezevic
I need a simple QoS that will reserve bandwidth for VOIP over L2VPN link.
One member posted this:
class-map match-all voice
match ip rtp 16384 16383-----> matches RTP audio or
Match access group name voice
ip access-list extended voice
permit udp 10.10.10.0 0.0.0.255 any eq range 16384 32767
class-map match-all voice-wan
match ip dscp ef
policy-map ingress
class voip
set ip dscp ef
policy-map WAN
class voice-wan
priority percent 25 ---(depends upon the BW u want to assign)
class class-default
fair-queue
interface fa0/1
service-policy input ingress
interface s0/0
sevice-policy output WAN
I think it is what I need but I have one question. If the egress interface is 1G interface but shaped to 5M by the provider, will the priority percent 25 command take into account whole 1G link or it will simply take 25 percent of available bandwidth?
In other words, do I need to set bandwidth on that link or this will work like this?
Thanks in advance!
Hello
It would be suggested to shape your wan link to the committed access rate of you ISP , setting the bandwidth directly on the physical interface wouldn't actually change the line rate it would only be used by routing protocol for path calculation.
Bellow is a possible example of shaping you wan link at 5mb whilst providing 15% of low latency queuing for your voice traffic
The acl matches on common uidp/tcp voice and signaling ports
access-list 100 permit udp any any range 16384 32767
access-list 100 permit tcp any any eq 1720
class-map VOIP_cm
match access-group 100
policy-map VOIP_pm_child
class VOIP_cm
priority percent 15
class class-default
fair queue
policy-map VOIP_pm_parent
class class-default
shape average 5120000 bc 80000
service-policy VOIP_pm_child
int x/x
description WAN link
service-policy output VOIP_pm_parent
Kind Regards
Paul
Hello
class-map VOIP_cm
class VOIP_cm
priority percent 15
class class-default
fair queue
class class-default
int x/x
Kind Regards
Paul
Thank you, Paul.
In my case, it's a communication between two offices on a separate port (L2VPN). So in your example I wouldn't use my WAN interface, but my L2VPN interface?
Also, on top of L2VPN provided by ISP, GRE over IPSec is configured. Is that an issue for your example?
