QOS for voice
gauravm
hi all,
i have configured LLQ for voice traffic.but still the voice gets choked at one end after sometime.could someone help me in this .i m attaching below the output of the h policy map command:
Policy Map VOICE
Class voice_packets
Strict Priority
Bandwidth 10 (kbps) Burst 250 (Bytes)
Class voice_signal
Bandwidth 8 (kbps) Max Threshold 64 (packets)
Class class-default
Flow based Fair Queueing
Bandwidth 0 (kbps) Max Threshold 64 (packets)
also , please let me know ,what does it mean by threshold here and the bandwidth 0 kbps
Thanks in advance.
what are your classes (voice_packets and voice_signal) matching on ? Assigning only 10 and 8 kbps might be too low for the actual voice traffic volume. Can you post the entire configuration of your router ?
GP
class-map match-all voice_signal
match access-group 112
class-map match-all voice_packets
match access-group 111
access-list 111 remark ** Voice packets **
access-list 111 permit udp any any range 16384 32767
access-list 112 remark ** Voice Signaling **
access-list 112 permit tcp any any eq 1720
access-list 112 permit tcp any eq 1720 any
access-list 112 permit tcp any any range 2000 2002
policy-map VOICE
class voice_packets
priority 10
class voice_signal
bandwidth 8
class class-default
fair-queue
kindly respond urgently..
first of all, the class-map voice_signal has been configured with ´match-all´, which means that it has to match each statement in your access list 112, I would change that to ´match-any´.
Also, as stated before, the bandwidth assigned to the classes might be too low, you could try and use ´set dcsp cs5´ for both classes, instead of assigning a bandwidth.
So your config would look like this:
class-map match-any voice_signal
policy-map VOICE
class voice_packets
set dscp cs5
class voice_signal
set dscp cs5
class class-default
fair-queue
Can you try and see if that makes a difference ?
GP
spremkumar
Level 9
Level 9
In additions to GPs post if u want to make your life/work simpler try auto qos option in your boxes on both the ends.
but do remember to go thru the prequiste while doing that like u need to chek up the B/W coded on ur interfaces and also better to have somebody ther in the remote end while doing this.
this link can take you up there..
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802000a7.html#wp1075284
regds
