QoS for VoiP best Practice
Greg Maaaag
Hello, guys!
We've got vpn-concentrator and 15 offices with 881w and 1941 isr connected vo it via ipsec. Our Asterisk is placed behind this vpn-concentrator in local network, so all traffice goes throung vpn tunnels.
Is it possible to make QoS rules using just destination IP address of our Asterisk server?
7 Replies 7
mahmoodmkl
Level 7
Level 7
yes u can do this with a acl
thank you for the answer!
what is more preferable to use in police-map for voice traffic: bandwidth or priority?
mahmoodmkl
Level 7
Level 7
both options have different function
bandwidth option will have policing while priority will have polcier
Can you suggest any manual with explanation of differences? I read some articles and forums over the internet and sa I undestand, priority match LLQ traffic with high priority wich will pass through router at first without depending on it's load and bandwidth doesn't match traffic with priority but gives stable % or kbps of throughput ?
Is there any best practice for matching and configuring voip traffic for qos?
We have channel bandwidth 20mb\s from ISP
I made this:
class-map match-any VOICE-CONTROL
match ip dscp cs3
match ip dscp af31
match protocol rtcp
match protocol mgcp
class-map match-any voice
match ip dscp ef
match access-group 106
policy-map qos
class voice
  priority percent 20
  set ip dscp ef
class VOICE-CONTROL
  bandwidth percent 2
  set ip dscp cs3
ip access-list extended VoIP-Control
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit udp any any eq 2427
permit tcp any any eq 2428
permit tcp any any range 2000 2002
permit udp any any eq 1719
permit udp any any eq 5060
access-list 106 permit ip any asterisk_ip 0.0.0.3
access-list 106 permit ip any another_asterisk_ip 0.0.0.255
interface GigabitEthernet0/0
ip address * 255.255.255.240
ip flow ingress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map vpn
service-policy output qos
Is it ok?
I would do it like this:
1. Configure Auto-QoS on L2 access switches (as close to the source of voice traffic as possible).
2. Create  class-maps that will match to VoIP traffic and Voice control traffic.
3. Create policy-map that will prioritize these traffic.
1. Marking:
mls qos
int g0/1
auto qos cisco-phone
ip access-list extended VOICE-SIGNAL
remark filter H323 traffic
permit tcp any range 1718 1720 any
permit tcp any any range 1718 1720
remark filter MGCP
permit udp any range 2427 2428 any
permit udp any any range 2427 2428
permit tcp any range 2000 2002 any
permit udp any any range 16384 32776 dscp ef
2. Class maps
class-map voice_traffic
match ip dscp ef
match access-group name VOICE
class-map voice_control
match ip dscp cs3
match access-group name VOICE-SIGNAL
3. Policy-map
policy-map VOIP_QOS
class voip_traffic
   priority percent 20
class voice_control
   priority percent 2
policy-map SHAPE
class class-default
   shape average 20000000
   service-policy VOIP_QOS
http://www.cisco.com/en/US/tech/tk543/tk759/technologies_white_paper09186a00801348bc.shtml#wp39463
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Greg -
"Cisco QOS Exam Certification Guide (IP Telephony Self-Study), Second Edition" as a source of a lot of very thorough and detailed information.  It is available on Safari at: http://my.safaribooksonline.com/book/certification/cisco-qos/1587201240
