Delete class from existing policy-map ?
wmtski666
How do you delete a class from an existing policy map?  For, example, if I have:
class-map match-all telnet-class
  match access-group 102
class-map match-all voice-class
  match access-group 103
policy-map voip-telnet-outbound
class voice-class
  priority 100
class telnet-class
  bandwidth percent 30
access-list 102 permit tcp any any eq telnet
access-list 103 permit ip 192.168.230.0 0.0.0.255 any
... and I want to delete the voice-class from the voip-telnet-outbound policy, what command would do that?
And, once it is deleted, would the changes automagically apply to any interfaces that voip-telnet-outbound is applied to?  Or, would I need to do another "service-policy output voip-telnet-outbound" command on the interfaces?  Or would I need to do something like shut the interface down and then restart it?  Or something else?
I tried "no class voice-class" when configuring the voip-telnet-outbound policy-map, but it didn't do anything.
Edison Ortiz
IOS and platform, please.
I tried here on 7200 with 12.4(15)T17 and it worked as expected
class voice-class
  priority 100
class telnet-class
interface FastEthernet0/0
no ip address
duplex auto
speed auto
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#policy-map voip-telnet-outbound
R1(config-pmap)#no class voice-class
class telnet-class
no ip address
duplex auto
speed auto
conf t
