QoS Not working as expected
Hi Guys,
I am at my last rope here with this situation, we have contacted our ISP who does Cisco and they have been unable to create a proper working configuration for what I believe is a rather simple request, they rather refer us to a IBC (Private network) setup...
The situation is as follows;
2 sites both connected to the Internet using ADSL2, they both also have Cisco 877 routers, there is a DVTI IPSEC setup between the sites to route traffic through the Internet.
At each site there is also a phone system, 1 site has the master and the other the slave, the problem is with out QoS when the branch office downloads a file from the main office the main office saturates its upload link (1Mbps) and the call quality drops to almost 0%
So the question is how can we setup the QoS to guarantee as much as 50% of bandwidth will goto the phone system IF it requires?
I can attach the configurations but did not want to clutter up the thread unless requires
Kind Regards,
Andrew James
6 Replies 6
u1kumar2002
    To run QOS for phones. you can make a class map for phone(VOIP) then make a policy map QOS  match the class VOIP in that strict priority of 30%. then for class default - remaining. Apply that class map to Virtual template.
For example : http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gtIPSctm.html#wp1085879
Refer Dynamic Virtual Tunnel Interface with QOS.
Hope this information will help you..
Do rate for helpful posts...
Uttam
http://www.startnetworks.blogspot.com
Thank you for that, after going over the configuration provided by the ISP it appears they dont even touch the SVTI (sorry made spelling mistake before)
Please note the below configuration does not work, this configuration appears to be over complicated and a bit redudant
class-map match-any MATCH-VOIP
match  precedence 5
class-map match-any TAG-VOIP
match access-group name LOCAL-VOIP
policy-map QOS
class MATCH-VOIP
  priority percent 35
policy-map QOS-IN
class TAG-VOIP
  set ip precedence 5
interface Tunnel1
bandwidth 865
ip address 172.30.0.1 255.255.255.252
ip route-cache flow
load-interval 30
qos pre-classify
tunnel source Dialer1
tunnel destination xxx.xxx.xxx.xxx
tunnel mode ipsec ipv4
tunnel path-mtu-discovery
tunnel protection ipsec profile Site-to-Site
interface Vlan1
description --- Ethernet to Customer ---
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1400
service-policy input QOS-IN
hold-queue 100 out
interface Dialer1
bandwidth 865
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip route-cache flow
load-interval 30
service-policy output QOS
ip access-list extended LOCAL-VOIP
permit ip host 10.0.0.200 any
permit ip host 10.0.0.201 any
permit ip host 10.0.0.202 any
I have created the following configuration do you believe this is on the right track?
match access-group name VOIP-SERVERS
policy-map QOS
class MATCH-VOIP
  set ip precedence 5
  priority percent 50
  set dscp ef
class class-default
  fair queue
interface Tunnel1
ip nbar protocol-discovery
ip access-list extended VOIP-SERVERS
lucio_cosare
Hi Guys,
Can someone help me?
I had some issues with the QOS i applied from my lab setup. This configuration actually works and tested working from a lower IOS. I cant remember the exact version but it is around version 12. Now, i upgraded my IOS and now the current version I am using is (C2800NM-ADVENTERPRISEK9-M), Version 15.1(3)T4 from a Cisco 2811 router. Below is my running configuration related to QOS.
ip access-list extended acl-181758
 permit ip any 10.128.0.96 0.0.0.15
ip access-list extended acl-181706
 permit ip any 10.128.0.112 0.0.0.15
class-map match-any cm-realtime
 match protocol dns
 match  dscp ef
 match protocol rtp
 match protocol ssh
 match protocol icmp
class-map match-any cm-181758
 match access-group name acl-181758
class-map match-any cm-181706
 match access-group name acl-181706
policy-map pm-terminal
 class cm-realtime
  priority
policy-map pm-system-small
 class cm-181758
  bandwidth 256
  police rate 256000
  service-policy pm-terminal
 class cm-181706
  bandwidth 512
  police rate 512000
policy-map pm-interface-ob110001
 class class-default
  shape average 960000
interface FastEthernet0/1/0
 description "PPPOE OB110001"
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
 service-policy output pm-interface-ob110001
I am using iperf tools for unix to generate traffic and at the same time to measure the traffic passing.
Hi Guys,
I already solved the problem...
I just missed one line of config as shown below..
 class class-default
  service-policy pm-system-small <----i missed this line.
Thanks..
Joseph W. Doherty
Are these Internet connections devoted to only your site-to-site VPN, or do you allow general Internet traffic too? If the latter, you'll not be able to have effective QoS unless both ISPs are willing to implement QoS on their devices that feed your devices.
