QOS on 1841 with ACL Help
sam
I have a customer that wants to prioritize printing on tcp port 9100 and handheld scanners on tcp port 11590 in addition to the current prioritization of Avaya IP Office VoIP.  Web browsing would be the lowest priority out of the three .  I'm not quite sure how to do this as I believe this will require an ACL as the packets are not tagged by the respective devices.  Here's what I have now on the remote router:
class-map match-any VOIP
match  dscp ef
class-map match-any IPSI
match  dscp af41
policy-map AVAYA-QOS
class VOIP
  priority percent 40
class IPSI
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
interface Multilink1
ip address 172.16.1.1 255.255.255.0
max-reserved-bandwidth 100
service-policy output AVAYA-QOS
no ip route-cache cef
no ip route-cache
no ip mroute-cache
no cdp enable
ppp multilink
ppp multilink group 1
6 Replies 6
cadet alain
The policy you posted is applied on a PPP multilink but are the printers and scanners communicating over this leased line to other offices?
Or is it inside the LAN between VLANs?
If traffic is not QoS marked then yes to match it you'll need an ACL.
Regards.
Alain.
Cadet,
Everything goes across the multilink, no VLAN's on either side.  What I need direction on are the commands for the ACL and then the corresponding class-map and policy map commands re. the ACL.
then you could do something like that:
ip access-list extended PRINT
permit tcp any any eq  9100
permit tcp any eq 9100 any
ip access-list extended SCAN
permit tcp any any eq 11590
permit tcp any eq 11590 any
class-map match-any  PRINT_SCAN
match access-group name PRINT
match access-group name SCAN
class VOIP
  priority percent 40
class IPSI
  bandwidth percent 5
class PRINT_SCAN
  bandwidth percent xx
class class-default
  fair-queue
  random-detect
This would guarantee a minimum bandwidth for this traffic in case of congestion.I would also not put printing and scanning in a LLQ with a priority command like Joseph remrked.
I don't know how much bandwidth you want to set so I left it as xx and what is IPSI so I put the class command just before the class-default but don't forget that the position of the class command is important.
Regards.
Alain.
Disclaimer
The       Author of this posting offers the information contained within  this      posting without consideration and with the reader's  understanding   that    there's no implied or expressed suitability or  fitness for any    purpose.   Information provided is for informational  purposes only  and   should not   be construed as rendering professional  advice of any  kind.   Usage of  this  posting's information is solely  at reader's own  risk.
Liability Disclaimer
In       no event shall Author be liable for any damages whatsoever     (including,   without limitation, damages for loss of use, data or     profit) arising  out  of the use or inability to use the posting's     information even if  Author  has been advised of the possibility of    such  damage.
Posting
Sorry, guess I wasn't clear (although I agree you probably wouldn't want either of these traffic types in LLQ).
What I meant for printing traffic, I generally wouldn't recommend it be prioritized over any other traffic, reference the original post's "I have a customer that wants to prioritize printing . . . "  In fact, printing is the type of traffic I often like to deprioritize it.  In this instance, I would suggest leaving it in the default-class as long as that class is configured with FQ.  (With the current policy, assuming this is pre-HQF IOS, and when using class-default FQ, recommend other non-LLQ classes only be used to deprioritize.)
Joseph W. Doherty
Disclaimer
Posting
You're correct, you need an ACL.  The ACL would be used by a class-map's match statement (match access-group ?), which in turn would be used by a policy-map statement.
PS:
Generally, would recommend against prioritizing printer traffic.
Thanks to you both!  We will implement tomorrow.
