QOS on 827 router
harmander.singh
Hi Guys,
I was applying QOS on a 827 router. As soon as the policy is applied to interface dialer 1, the router will freeze and then we have to reboot it. The qos is for voice calls through the router. The voice system is avaya so every thing goes through the router is pure ip. Please find below the the configuration of the router. Please let me know whether there is a bug or I am doing some thing wrong. The adsl link is 256/64K.
Implementing this on Sydney works OK. Implementing it on Mlebourne kicks me off and they lose connectivity completely.
class-map match-all EF
match access-group 101
class-map match-all platinum
match ip dscp ef
class-map match-all best-effort
match access-group 105
class-map match-all AF3
match access-group 104
class-map match-all premium
match ip dscp ef
policy-map VOIP
class platinum
priority 38
policy-map SETDSCP
class EF
set ip dscp ef
class AF3
set ip dscp af31
access-list 101 permit udp any any range 16384 32768
access-list 102 permit tcp any any eq tacacs
access-list 104 permit tcp any any eq www
access-list 105 permit ip any any
interface Ethernet0
service-policy input SETDSCP
interface Dialer1
service-policy output VOIP
Tks & Rgds
spremkumar
Level 9
Level 9
hi
quick check about CEF whether its enabled in your box ?
u did say that @ sydney everything is fine but it hogs u up in melbourne ru using the same h/w boxes at these locations ?
from ur post i read that you are marking ur inbound packets at the closet of ur source itself(i.e.,at ur eth0) and applying LLQ on the out in ur dialer dont find anything wrong with ur config .
regds
