Routing on IPLC and Tunnel
rahul_gaur
Dear All,
I have got two routers residing in London and Delhi.
The problem is we have at both ends 2 ISP connection.
At the Delhi end we have Sify which is connected to Cisco 2801 F0/0 port and another IPLC is connected on s0/0/0.
I have made a GRE tunnel from my Delhi router to London router using Internet.
I have 24 IP Phones connected through Tunnel0 and they r working fine.
The Problem is i need to connect 7 IP Phones out of 24 through IPLC to BCM residing in london which is connected through Cisco 2811 f0/0. I need to route the traffic of IPLC through the same port i.e 10.10.10.1.
Can someone help me with the routes.
spremkumar
Level 9
Level 9
hi
i feel u can do this using source based routing.
Match your source ip address which is ur blue subnet and set the destination as the iplc link instead of your gre tunnel which is created over the internet connection.
If u still need to tweak the config lines you can match both source and destination and route them thru IPLC.
Pls find the link which will take u in detail about configuring the same in ur box..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca590.html
regds
