QOS on cisco 800 series
davidbuit
I have configured the following on my cisco 800 series routers to priorotise traffic across my 4MB link. I am not sure if I have got the config correct as I seem to get delays with normal traffic like Citrix. Please can anyone advise on the method used ad if there is a better way of doing this?
class-map match-any VOICE
match access-group 111
policy-map LLQ
class VOICE
priority 1500
set ip precedence 5
class class-default
fair-queue
policy-map PARENT
class class-default
shape average 3920000
service-policy LLQ
interface FastEthernet4
ip address 172.16.0.1 255.255.255.0
load-interval 30
service-policy output PARENT
access-list 111 permit ip 10.10.40.0 0.0.0.255 10.10.30.0 0.0.0.255
access-list 111 permit udp any any precedence critical
8 Replies 8
spremkumar
Level 9
Level 9
which cisco router model you are using up over there ?
i dont think cisco 800 series model is capable of handling 4Mbps link with all qos flavors configured on it.
regds
It is a Cisco 871 router.
hi
are you trying to configure qos on an internet link ?
QOS configurations has to be an end to end configuration where in any break in between will not yield the desired results for you.
regds
Thanks for the reply. No, this is not over an internet link. It is a dedicated link between two sites. It is rated limited to 4MB by the ISP.
Ta
hi
can you confirm whether your SP is honouring your marking out there in his PE router and mapping the same to his backbone markings ?
If he doesnt honour your marking and dont map it with his backbone markings you may end up in experiencing packet drops.
regds
Usually citrix will use TCP ports 1494, 2598 and UDP port 1604.
access-list 110 remark Citrix-Prioritization
access-list 110 permit tcp any eq 1494 any
access-list 110 permit tcp any any eq 1494
access-list 110 permit udp any eq 1604 any
access-list 110 permit udp any any eq 1604
access-list 110 permit tcp any eq 2598 any
access-list 110 permit tcp any any eq 2598
class-map match-any CITRIX
match protocol citrix
match access-group 110
policy-map OUTBOUND
class CITRIX
priority percent
class class-default
fair-queue
interface Fastethernet 4
service-policy output OUTBOUND
If you are using any other ports you can create an ACL for that.
Hope this might help you..
Rajesh
Thanks Rajesh...
What would be the best way to include QOS for my voice traffic? Voice traffic is defined using this acl
Thanks!
description CITRIX
description VOIP
match ip dscp ef
match ip precedence 5
policy-map OUTBOUND
class CITRIX
priority percent
class VOICE
priority percent
class class-default
fair-queue
max-reserved-bandwidth <----Add this line, if the total percentage goes above 75%
