QOS on router with Avaya Phone System
TRACY HARTMANN
We need to add Qos to two routers that have a point to point T1s.  We are using a Avaya PBX and Avaya devices by default will tag all voice packets with
DiffServ Code Point DSCP- 46 (Expedited Forwarding),
and signaling with
DiffServ Code Point- DSCP 34
What is the best way to setup the QOS?
Terry Cheema
Tracy,
You can use LLQ. LLQ consists of a priority queue for Voice traffic + CBWFQ for other classes. This model helps priortise Voice traffic and at the same time ensures other traffic is not starved.
Assuming you are using Cisco switches - Configure them to trust the markings at the source. The markings will be passed onto routers and at routers you can configure appropriate QoS mechanism.
At a very basic example:
R1(config)#class-map match-all VOIP-RTP
R1(config-cmap)#match dscp ef
R1(config)#class-map match-all VOIP-SIGNALING
R1(config-cmap)#match dscp afx      <<< chose acording to what your signaling is (34 - is af41 - normaly reserved for Video in Cisco)
R1(config)#policy-map VOIP
R1(config-pmap)#class-map VOIP-RTP
R1(config-pmap-c)#priority [kbps] or use priority %
R1(config-pmap)#class-map VOIP-SIGNALING
R1(config-pmap-c)#bandwidth [kbps ] or bandwidth percent
R1(config)#interface s0/0/0:0
R1(config-if)#service-policy out VOIP
You can setup more match criteria ACLs etc and add more classes. Its just a direction to start with.
Terry
I think this will work for us, I am going to test it out next week.  Is there a way to monitor the usage from the router?
You can verify by running the command:
Sh policy-map interface
This will show you counters etc.
Let us know how did you go.
Terry
Please rate helpful posts!
