SWITCH PROBLEM DUE TO DUPLEX
sukesh tandon
hi all,
This is sukesh working for dimension data.
I had a small query regarding the switch details.giving the show arp command in the router i was unable to find the switch in lan .Once the port of the router connected to switch was made auto duplex it started showing in LAN .At this moment of time i was able to see it with help of sh arp command.but still unable to ping it. Can anyone of you explain whether it was due to the duplex mode or anything else.
feel free to contact me on sukki151190 @Gmail.com
Regrads,
Sukesh Tandon
milan.kulik
Level 10
Level 10
are you sure the IP address configured on the switch is correct?
Have you tried to enable CDP on the router and check by issuing
sh cdp nei detail
command?
HTH,
Milan
Check Duplex and Speed Setting
Check Ports in are in Proper Vlans
Jawad
Hi Milan,
The switch is configured with a proper IP address.
I have not tried to enabe cdp in it .
feel free to contact me on sukki151190 @gmail.com
Regrads,
Sukesh Tandon
