QoS Prioritzation for PS3 over DSL
Chris Russo
I am trying to prioritize traffic for my PS3 to take priority over the other devices on my LAN. When I try to apply the service-policy to the ATM PVC is it not taking. I have two requirements:
1)Prioritize PS3 traffic to 80 %
2)Police the outbound traffic to 7.2 Mbps due to a bufferfloat issue
Here is my current config for a policer:
policy-map POLICE_OUT
 class class-default
   police cir 720000
     conform-action transmit
     exceed-action drop
interface ATM0/0/0.1 point-to-point
 pvc 0/32
  service-policy output POLICE_OUT
  pppoe-client dial-pool-number 1
Here is the config I am trying to use but whenever I apply the service policy, it doesn't take/commit. I don't get any
ip access-list standard PS3
 permit 192.168.0.4
class-map match-any PS3
 match access-group name PS3
class-map match-all OTHER
 match any
policy-map TEST
 class PS3
    bandwidth percent 79
 class OTHER
    bandwidth percent 20
 class class-default
   police cir 720000 bc 22500
     exceed-action drop
12 Replies 12
Philip D'Ath
It would help to know what the router is, and what software version you are using.
Try putting everything on the one physical interface.
interface ATM0
 pvc 0/132
 vbr-nrt 500 500
 tx-ring-limit 3
 dialer pool-member 1
 service-policy out POLICE_OUT
It is a 1841 running 12.4T(13r), put my configs on the physical ATM interface and not the subinterface?
interface ATM0/0/0
 no ip address
 no atm ilmi-keepalive
 bundle en
 dsl operating-mode auto
 pvc 0/32
Delete the entire sub-interface, and use something more like what I supplied.
You might need to move to a 15.x IOS train to make this work.
Ok I put the configs on the physical ATM interface and it took the command. The issue now is that it is not catching the traffic coming from the PS3 or OTHER_TRAFFIC classes, only the class-default.
ChrisRouter#sh policy-map interface
 ATM0/0/0
  Service-policy output: TEST
    Class-map: PS3 (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name PS3
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
      bandwidth 79% (704 kbps)
    Class-map: OTHER_TRAFFIC (match-any)
      0 packets, 0 bytes
      Match: access-group name OTHER
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      bandwidth 20% (178 kbps)
    Class-map: class-default (match-any)
      16798 packets, 3150774 bytes
      5 minute offered rate 51000 bps, drop rate 0 bps
      Match: any
      police:
          cir 720000 bps, bc 22500 bytes
        conformed 16450 packets, 2753004 bytes; actions:
          transmit
        exceeded 307 packets, 394742 bytes; actions:
          drop
        conformed 57000 bps, exceed 0 bps
Your ATM interface is referencing a policy called POLICE_OUT, while your service policy appears to be called TEST.
This is what is configured for:
interface ATM0/0/0
 no ip address
 bundle en
 service-policy output TEST
 pvc 0/32
end
I'm thinking that by the time it is checking your access list the traffic is already NAT'd.  Hence no match.
I think you would be better matching on a DSCP QoS marker, and mark the PS3 traffic on the way into the router.
so mark it by applying a service policy to the LAN interface as it comes in with DSCP values? I have to do this per IP because the PS3 cannot tag any traffic with DSCP values in the IP header.
Yes, exactly.
You may be able to do it on the actual physical port that the PS3 plugs into.  This would make it easy, since you would just be tagging every packet.
oh ok thanks I'll play with that.. Are you sure this isn't anything to do with how my class-maps are built? Kinda weird how it is being NATed before QoS
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Well, I guess one could argue, you want to apply QoS to the packets, as they are, that will be transmitted.
BTW, if your DSL is aDSL, to make your QoS effective, you'll want to shape egress for your logical outbound/upstream bandwidth limit, otherwise, QoS (excluding your policing statement) won't "trigger" until the interface congests.
Oh, and could you explain why you need to police for "bufferfloat"?
Lastly, you might find a simple class-default, using FQ, might well deal with your QoS needs (although you'll still need to shape).
Philip D'Ath
I have a ConfigWizard for Cisco 890 series routers.  It wont do exactly what you want, but take a look at how it generates the QoS configuration.
http://www.ifm.net.nz/cookbooks/890-isr-wizard.html
