Secondary dot1q tag? - Carry multiple VLANs in just one VLAN?
First of all apologies as I am a bit of a newbie but I have a question that I hope some folks on this could possibly shed some light on / lead me down the correct path.
I work in an enterprise campus / branch office style setup. all remote sites are connected over the providers WAN infrastructure (a multipoint l2 cloud), the provider will only carry traffic with an 802.1q tag of 400.
I want to use VRF lite between a number of sites to create a totally isolated segment, however I don't see how I can multiplex an additional VLAN onto the WAN to provide the segregation when the provider will only carry vlan 400.
Im using cisco 4321/1921 ISR's at the branch sites and have been looking into q-in-q but Im not sure as to how I should configure it / is this even possible?
Any ideas?
Thanks in advance :)
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Off the top of my head, cannot comment on 4321/1921 configurations for Q-in-Q, but generally what you're describing is how you use Q-in-Q, i.e. pass your VLANs across a provider's VLAN tagged infrastructure.
You should confirm, you provider won't have any issues.
I've only used Q-in-Q once, years ago, and in that case, my edge device was (?) a switch.  I also recall, it was very simple to configure.
