QOS setup...need help
musthafa786
We need to implement QOS in our LAN environment - access, distribution and Core level , How can we setup QOS for VoIP and video traffic more effectively, give me more realistic data ( I meant realtime configured detials)  or good document which more helpful , thanks.
Musthafa
Leo Laohoo
Duplicate post #1
Terry Cheema
Mohammed,
You can go through the QoS SRND doucment. It has the detailed information along with Config examples for various models of switches.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoSDesign.html
In brief -
What you would need is - At access ports connecting to the end points you can setup conditional trust (only trust markings from Cisco Phone). Setup/modify the cos-dscp map (on some switches it may be converting CoS5 to 40). Trust the dscp markings at trunks. Setup appropriate queueing. If its too much for you - You can use Auto QoS, it would do this all for you. It works fine mostly.
If you have any further questions, please feel free to let us know.
Terry
Didnt see Leo's reply before I posted. Mohammed please avoid opening duplicate posts where possible.
Terry
