QoS Shaping / Policy Map
tpfrankli
Level 5
Level 5
So I'm trying to wrap my head around shapping and nested MQC. I have a site with a 10Mbps MPLS connection delivered via 100Mbps ethernet. So the CIR from the provider is 10Mbps. However when trying to stress test this thing with QoS enabled I can't ever seem to get above 4Mbps. I'm wondering if some QoS / Shapping experts can take a look at my config and tell me where I'm going wrong.
class-map match-any GDOI
match access-group name gdoi
class-map match-any VoIP-Bearer
description VoIP Bearer Channels
match ip dscp ef
class-map match-any Control
description VoIP Control Channels
match ip dscp af31
match ip dscp cs3
class-map match-any VideoConf
description Video Conferencing
match ip dscp af41
policy-map child_wan
class GDOI
    bandwidth remaining percent 10
class VoIP-Bearer
    priority percent 30
class Control
class VideoConf
    bandwidth remaining percent 25
class class-default
    fair-queue
     random-detect
policy-map SHAPE_TRAFFIC_FROM_WAN
class class-default
    shape average 9000000 90000
  service-policy child_wan
policy-map SHAPE_TRAFFIC_TO_WAN
class class-default
    shape average 10000000 100000
interface GigabitEthernet0/0
description Ethernet LAN/Switch
ip address X.X.X.X 255.255.255.252
no ip redirects
no ip unreachables
ip flow ingress
load-interval 30
duplex auto
speed auto
service-policy output SHAPE_TRAFFIC_FROM_WAN
interface GigabitEthernet0/1
description 10 MB Ethernet MPLS
mtu 1600
bandwidth 10000
no ip redirects
no ip unreachables
ip flow ingress
ip flow egress
load-interval 30
duplex full
speed 100
no cdp enable
crypto map lanGDOI-map
service-policy output SHAPE_TRAFFIC_TO_WAN
Rate helpful posts
Blog - http://tripplehelix.net
~~~ Rate helpful posts Blog - http://tripplehelix.net
Umesh Shetty
Hi Friend,
While I look into your config can I suggest you one thing, on your WAN interface GigabitEthernet0/1 can you please set the command speed 10 this way you will drive the physical inteface down to 10 mbps and hence no shaping will be needed.
Umesh Shetty
10 Replies 10
Umesh Shetty
Hi Friend,
Umesh Shetty
tpfrankli
Level 5
Level 5
Ugh great thanks Cisco forums, this is not possible the provider is giving us a 100Mbps PHY. Anyone know how to mark this as unanswered since I stupidly hit the correct answer button?
Rate helpful posts
What is your IOS version? I just ran into this problem where calculations weren't happening correctly because of a change in the IOS code. If you're higher than 12.4(20)T, you may need to put a bandwidth statement in your class default on the parent policy:
class class-default
    bandwidth 10000
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Currently running 12.4-22.T1, do you know the open bug ID on that?
Rate helpful posts
There's no bug that I'm aware of, but your calculations could be way off. You have a post-hqf image, which Joseph, another engineer on this forum explained to me the other day.
There are a couple of questions that I have though.
How are you testing?
Is there anything else going through the router at the time of testing? If you have 6mb already allocated to something else, then you'll only have 4Mb left over to use.
Can you post "show policy-map inter"?
Can you post "show int"?
HTH,
John
Hi Friend
Can you possibly post the output of the show policy-map interface GigabitEthernet0/1 and show interface
GigabitEthernet0 when the traffic is hitting 4 Mbps>
Umesh Shetty
So here's the output, really I can barely get it to climb above 3Mbps.As far as testing I'm doing an extended ICMP ping with a payload of  18024 bytes from the router to my core router which is fed via a OC-3 which is barely at 10% utilization so I know it's not the bottle-neck. I'd expect this to get snapped up in the default-class which given there is little to no other traffic on the circuit should be able to burst above its allocation, which I do see given the offered rate is higher than the reservation.
show policy-map interface gi 0/1
GigabitEthernet0/1
  Service-policy output: SHAPE_TRAFFIC_TO_WAN
    Class-map: class-default (match-any)
      1361774 packets, 550748484 bytes
      30 second offered rate 2409000 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/75/0
      (pkts output/bytes output) 1535472/569634501
      shape (average) cir 10000000, bc 100000, be 100000
      target shape rate 10000000
      bandwidth 10000 kbps
      Service-policy : child_wan
        queue stats for all priority classes:
          Queueing
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 238575/40857018
        Class-map: GDOI (match-any)
          4 packets, 416 bytes
          30 second offered rate 0 bps, drop rate 0 bps
          Match: access-group name gdoi
            30 second rate 0 bps
          Queueing
          (pkts output/bytes output) 4/472
          bandwidth remaining 10% (700 kbps)
        Class-map: VoIP-Bearer (match-any)
          238575 packets, 40857018 bytes
          Match: ip dscp ef (46)
          Priority: 30% (3000 kbps), burst bytes 75000, b/w exceed drops: 0
        Class-map: Control (match-any)
          72685 packets, 10026382 bytes
          30 second offered rate 10000 bps, drop rate 0 bps
          Match: ip dscp af31 (26)
            31765 packets, 4247502 bytes
            30 second rate 5000 bps
          Match: ip dscp cs3 (24)
            40920 packets, 5778880 bytes
          Queueing
          (pkts output/bytes output) 72685/10026382
        Class-map: VideoConf (match-any)
          0 packets, 0 bytes
          Match: ip dscp af41 (34)
            0 packets, 0 bytes
          Queueing
          (pkts output/bytes output) 0/0
          bandwidth remaining 25% (1750 kbps)
          1050510 packets, 499864668 bytes
          30 second offered rate 2398000 bps, drop rate 0 bps
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops/flowdrops) 0/75/0/75
          (pkts output/bytes output) 1224209/518750755
          Fair-queue: per-flow queue limit 16
show int gi 0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 000a.b86c.6829 (bia 000a.b86c.6829)
  Description: 10 MB Ethernet MPLS
  Internet address is X.X.X.X/30
  MTU 1600 bytes, BW 10000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 93/255, rxload 88/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:56:48
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 75
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 3451000 bits/sec, 395 packets/sec
  30 second output rate 3656000 bits/sec, 434 packets/sec
     1312327 packets input, 756090532 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     1546347 packets output, 581824391 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Rate helpful posts
Hi Friend,
I doubt if pinging from the router with a high payload will be able to generate the amount of load you intend to. I would suggest use a tool such as Iperf to generate the load. You could even try transferring some large data between two systems at the branch and headqaurters end. This will help you put actual load and test the BW on the link
Umesh Shetty
I agree with Umesh. You're going to need something more than an extended ping. Are you using a timeout of 0 when you're doing it? Either way, what does the normal utilization of the link look like? You said that you can barely get it above 3Mb, and if you're truly hitting class default, you've guaranteed 1750 to this class. You could be butting up against other classes that are already taking the bandwidth.
HTH,
John
That's the thing normally the link is pretty empty. I managed doing a delay of 0 getting the link up to 4.2mbps, I do have some minor traffic 150kbps in other queues but it seems like this is caping out around 4.2mbps. I am getting a machine put on the LAN to do an iperf with since I think you might be right the rotuer just can't generate enough traffic.
Rate helpful posts
