QOS to a destination address not a port or application
bchoisser
I am trying to find a way to implement QOS for a destination IP address. The traffic is port 80 traffic. But this needs to have a much higher priority to a specific server on our network over a WAN connection. I have implemented QOS for specific applications and ports but haven't found much information going to a destination IP.
Thanks for your help.
Brandon Buffin
You can use the "match access-group" command in class-map configuration mode to match traffic based on an ACL. This will accomplish QoS based on IP address. Please take a look at the following document regarding QoS commands.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a008008079c.html
Hope this helps.
Brandon
