qos
ksnarayan43
Hi : Below is a sample config on rate limit
For your example this could be the configuration
! Your access-list defining your internal ! traffic
access-list 101 permit ip x.x.x.x y.y.y.y any
access-list 102 permit ip a.a.a.a b.b.b.b any
access-list 110 permit ip c.c.c.c d.d.d.d any
!class maps matching your access-list
class-map 1cust
match address 101
class-map 2cust
match address 102
class-map 10cust
match address 110
policy-map shape-cbwfq
class 1cust
!gurantee of 1mbps shaping it to 5Mbps if !bandwidth available
bandwidth 1000
shape peak 5000000
class 2cust
bandwidth 1000
shape peak 5000000
class 10cust
bandwidth 1000
shape peak 5000000
interface fastethernet0/0
desc outside interface connected to internet
service out shape-cbwfq
The above config works for rate limiting, the question i have , within the customer1 (1cust)group, can we shape the traffic by IP subnets etc
thank you
Laurent Aubert
if you want to apply treatment per subnet per customer and not per customer anymore, you need a class-map per subnet which match a dedicated ACL which match this subnet.
Laurent.
Giuseppe Larosa
Hello Krishnan,
you need to used nested policy maps hierarchical policies to achieve this.
For example see
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a0080114326.shtml#applyingaservicepolicy
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_mqc_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1060235
Recently a three level qos hierarchy has been introduced.
Hope to help
Giuseppe
