08-16-2023
08:16 AM
- last edited on
08-18-2023
10:37 AM
by
Translator
What does the ip mean? IP addresses? What is the difference between
deny ip any any and deny any any
Solved! Go to Solution.
08-16-2023
08:42 AM
- last edited on
08-18-2023
10:39 AM
by
Translator
Hello @hfakoor222,
deny ip any any
This ACL rule denies all IP traffic from any source IP address to any destination IP address. In other words, it blocks all IP packets, regardless of the source or destination. It effectively prevents any communication using IP-based protocols.
deny any any
This ACL rule is more generic. It denies all traffic, not just IP traffic. It blocks all types of communication, including IP, non-IP, and other layer 4 and above protocols. This rule is often used as a catch-all to deny all traffic when a more specific rule doesn't match.
deny ip any any
is used when you specifically want to block IP-based communication while allowing other non-IP protocols to pass through.
Deny any any
is used when you want to block all types of communication, regardless of protocol.
08-16-2023
08:42 AM
- last edited on
08-18-2023
10:39 AM
by
Translator
Hello @hfakoor222,
deny ip any any
deny any any
deny ip any any
Deny any any
08-16-2023
08:47 AM
- last edited on
08-18-2023
10:40 AM
by
Translator
yes IP address -
deny ip any any
explicit deny all (generally we use end of the line once we allowed the list on the top)
deny any any - default deny all
08-16-2023
11:29 AM
- last edited on
08-18-2023
10:43 AM
by
Translator
deny IP any any
ACE (not an ACL, but in an ACL), means block anything using IP (Internet Protocol).
Practically, today, any network traffic that's using L3, will use IP, but since IP is L3, it wouldn't block just L2 protocols or other L3 protocols, like Novell's IPX.
What might be a bit confusing, there are other ACE types, that are sub protocol types, which you can define on an ACE, like
permit/deny tcp
Usually these variants provide extra options, on the ACE, that only apply to that kind of ACE, like
tcp/udp
would allow you to also specify port numbers, which don't exist in other IP sub protocols. But, any IP packet, would have IP addresses.
As the other posters have already described,
deny any any
would block more than IP, but it might not block lower L2 protocols, e.g. like, perhaps, CDP, or LLDP.
08-18-2023 07:22 AM
