278
Jegatheesan
Beginner
RIP configuration in same network (RIP V1 & RIP V2)
Here I'm configuring 5 routers.
There are three areas RIP V1, RIP V2 and RIP V1.
How can I configure RIP V1 & RIP V2 in same network.
1 ACCEPTED SOLUTION
Hello @Jegatheesan ,
RIPv2 routers might be able to listen to RIPv1 broadcast updates with the command suggested by @Georg Pauwen .
RIP misses the concept of a neighbor state so this one way  routing is not an issue.
However RIPv1 routers will likely need a default static route pointing to the RIPv2 neighbor in order to have end to end connectivity.
To be honest even RIPv2 is not so used anymore just for learning.
Hope to help
Giuseppe
3 REPLIES 3
Leo Laohoo
VIP Community Legend
Please post homework questions at the Cisco Learning Network.
Georg Pauwen
VIP Expert
the main 'problem' is that RIP version 2 uses multicast address 224.0.0.9 for updates, whereas RIP version 1 uses broadcast address 255.255.255.255 for updates.
You can configure the interfaces with the command ' ip rip receive version 1 2'. Whether that works remains to be seen...
Hope to help
Giuseppe
