Question about IOS versions?
damonstarkey
I am running a Cisco 3725 Router with 12.3(17a) IPBASE and want to know if there is a way I can get the IPSec version of this software or a newer version. I saw an area in support where I can download it, but was not sure if I had to pay for it. Can someone help me please?
ciscobuddy
hi,
for this you required CCO id, then only you cann access that.
I have an account. So, if I go to the OS download spot and select the one I want I can use it without having to pay any upgrade fees? The Router I purchased only came with the IPBase OS installed on it.
yes, if you have CCO account, you can download IOS which you want to without paying any upgrade fees.
hope to help ... rate if it does ...
icabrera
Level 4
Level 4
Hi, if you want another feature set you should buy it and after download at CCO with your cco id.
Obviously, you can download it without paying but it's supposed you should pay for it, it's your decision.
