04-30-2019 12:37 PM
I have a video streaming device that needs to be in the DMZ. the problem is that the device must be close to the streaming equipment, which is in another building than the DMZ. It is using RTP (UDP) 5004. I would like interface GI9/47 on SwitchB to be where the device is plugged in, and also allow it to stream everything to a server in the DMZ.
Environment:
SwitchA is in BuildingA
SwitchB is in BuildingB
SwitchA manage the DMZ, with IP Hosts using 10.10.10.0 /24 addresses
SwitchA also manages IP Hosts using 10.1.10.0 /24 addresses
SwitchA is also connected to SwitchB via fiber
SwitchB manages IP Hosts using 10.7.10.0 /24 addresses
Is this possible, and / or safe to do?
Please, feel free to let me know if you have any other questions or ideas about how to set this up. Thanks, in advance, for any help you can provide!
04-30-2019 01:38 PM
04-30-2019 01:42 PM
Going on the information provided, and assuming a trunk link between switches, all that is needed is to tag the vlan that corresponds to the DMZ network on that trunk. The interface GI9/47 would then be a member of that vlan.
Network-wise the security policies which apply to traffic in the vlan should remain the same.
However, the physical security at site B would be something to consider.
