Question about upgrading CSR1000v software
kay.kang
We're running 16.3.x version on CSR 1000v and plan to upgrade to 16.12.x or 16.17.x.
I am wondering if it's possible to upgrade 16.3.x to 16.17.x or need to upgrade first another version.
And, how about 16.12.x? is there any issue to upgrade from 16.3.x to 16.12.x?
Thank you,
marce1000
- Check and read Release Notes of targeted version which you want to install , look for upgrade and installation info's
M.
balaji.bandi
personally, i would build a new virtual router with the latest version and move the config and cut over to a new one, any way upgrading and reboot still need downtime.  if any issue you need to downgrade bla bla,
BB
