Question related to Access-lists
flashsplash
Hi All,
I've got this problem.
First let me post my acc-list.
access-list 101 remark ====== OUTSIDE INTERFACE ACL =====
access-list 101 deny ip 192.168.0.0 0.0.255.255 any log
access-list 101 deny ip 172.16.0.0 0.15.255.255 any log
access-list 101 deny ip 10.0.0.0 0.255.255.255 any log
access-list 101 deny ip 127.x.x.0 0.255.255.255 any log
access-list 101 deny ip 255.0.0.0 0.255.255.255 any log
access-list 101 deny ip 224.x.x.0 31.255.255.255 any log
access-list 101 deny ip host 0.0.0.0 any log
access-list 101 deny ip 169.x.x.0 0.0.255.255 any log
access-list 101 deny ip any 0.0.0.0 255.255.255.0 log
access-list 101 deny ip any 0.0.0.255 255.255.255.0 log
access-list 101 permit ip any any log
access-list 102 remark ====== ONLY SOURCE TO INTERNET ACL =====
access-list 102 permit ip 192.168.2.0 0.0.0.255 any log
access-list 102 deny ip any any log
my problem is that when my dhcp release time is over, the acc-list stops it from getting the renew. the reason i discoverd this was because when i removed the ip access-group from the FA interfaces i directly get my address back.
any gelp would be appreciated.
TIA
bye flash
8 Replies 8
deepinder
Hi Flash,
All DHCP packets travel as UDP datagrams; all client-sent packets have source port 68 and destination port 67; all server-sent packets have source port 67 and destination port 68. For example, a server-side acl should allow the following types of packets:
Incoming packets from 0.0.0.0 or dhcp-pool to dhcp-ip
Incoming packets from any address to 255.255.255.255
Outgoing packets from dhcp-ip to dhcp-pool or 255.255.255.255
where dhcp-ip represents any address configured on a DHCP server host and dhcp-pool stands for the pool from which a DHCP server assigns addresses to clients.
eg
access-list 111 permit udp host 0.0.0.0 eq bootpc host 10.32.73.129 eq bootps
access-list 111 permit udp 10.32.73.128 0.0.0.63 eq bootpc host 10.32.73.129 eq bootps
Access-list 111 permit udp any eq bootpc host 255.255.255.255 eq bootps
If this info was of help to u please rate it.
Deepinder Singh Babbar
Hi flash,
Actually you do not need to take help of ACL for your DHCP requests. You can instead configure "ip helper-address x.x.x.x" on your LAN interface where x.x.x.x is the ip of your DHCP server. So, if your client sends a broadcast for a ip from DHCP, the router will convert the broadcast and send a unicast request to that particular DHCP ip if "ip helpder-address" is configured. Thanks!
Manoj
I agree with deepinder that you would need to permit udp ports 67 & 68 for DHCP to work when you have access-lists placed on the vlan
helper address wont help as the source of the DHCP broadcast carries an IP 0.0.0.0 which will be blocked by the access-list
just add the following to the beginning of your access-list
access-list 101 permit udp any any eq 67
access-list 101 permit udp any any eq 68
HTH, rate if it does
Narayan
*deepinder* thx for ur advice. i must say that i don't fully understand the command u have given [this doesn't mean i don't appreciate ur advice]. I will give it a look what that command exactly stands for.
*royalblues* also my thx goes out to you. ur advice is s'thing i understand.
I just have 1 question.
the advice u have given me doesn't the command:
acc-list 101 permit ip any any must take care of letting the udp packets go thru?
i'm using Fa0/0 for my wan and it's getting it's ip add from dhcp and 1 string in the acc-list is blocking the dhcp lease renewal when the time is expired. Do i need to remove a line from acc-list 101 or will adding the,
on top of the acc-list resolved this issue. I'm not only looking for the solution but also what i have done wrong.
ps: acc-list 101 is configured for inbound on int fa0/0
tia
bye flash...
When you add the access-list as inbound , the DHCP request goes but the response gets denied.
I asked you to add the above access-list as we do not know the source of the DHCP packet. It could be from a DHCP server directly or through a DHCP relay agent.
Just give it a try and see if it works.
you can then run a debug and allow the particular source of DHCP response and fine tune your access-list
Narayan
please rate all posts
Ok? i will add them and monitor it, as my dhcp lease is being refreshed every 1,5 day...
i'll keep in touch
bye flash...
Royalblues it seems that my problem is resolved...thx
bye flash
bye flash
ps: was looking for the rate option to rate ur post Royal but i'm missing this option. Any suggestions?
