06-21-2019 09:50 PM - edited 06-21-2019 10:00 PM
I am testing scenario in the LAB , here is the my setup
A (pair) < eBGP > B(pair) <iBGP>C (pair) < OSPF stub area> D (pair)
Looking for best configuration for C switch pair where the IBGP to OSPF and OSPF to IBGP takes place and should avoid any kind of route looping and also, I am fine protocols mutual redistribution with tags.
I dont need prefix list for route control because i am advertising few 100`s from A pair and few 100`s of routes from OSPF (D pair) and planning to control routes with tags or community ?
I have collected sample configuration from internet but still looking for best
Appreciated quick response
Kumar
Solved! Go to Solution.
06-25-2019 11:34 AM
Hi Giuseppe
As soon as i enable stub area on C and D pair default route getting over written by OSPF because the default route which i am originating from BGP(top pair) to IBGP with Ad is 200 so, OSPF is winning?
Without OSPF stub area
C pair routers(config-router-ospf)#show ip route 0.0.0.0/0 (receiving from upstream which is my core)
Gateway of last resort:
B I 0.0.0.0/0 [200/0] via 1.1.1.13, Ethernet10
via 1.1.1.15, Ethernet11
As soon as I enable totally STUB area.
C Pair router#show ip rou 0.0.0.0/0 (receiving from downstream)
O IA 0.0.0.0/0 [110/24] via 1.1.1.21, Ethernet14
via 1.1.1.25, Ethernet15
Kumar
06-25-2019 12:27 PM
Hello Kumar,
in our last posts we were speaking of using RIP on C1, C2 routers and not OSPF.
When using OSPF and OSFP stub area between C1,C2 and D1,D2 routers you don't need to send an iBGP default route to C1,C2.
Because C1 and C2 will send out a default route in stub area regardless the presence of a default route in IP routing table.
Your understanding is correct OSPF O IA has lower admin distance (110) then iBGP route (200).
How to fix this on C1 and C2 routers if you want to keep the iBGP default route installed ?
We could use a distribute-list in OSPF to deny the default route
access-list 11 deny 0.0.0.0
access-list 11 permit any
router ospf 10
distribute-list 11 in
or using a prefix-list if supported
ip prefix-list DENY-OIA-DEFAULT seq 5 deny 0.0.0.0/0
ip prefix-list DENY-OIA-DEFAULT seq 10 permit 0.0.0.0/0 ge 1 le 32
router ospf 10
distribute-list prefix DENY-OIA-DEFAULT in
Note:
being OSPF a link state protocol the distribute-list command only prevents the installation of filtered routes in the local IP routing table, but it does not change / filter the link state database.
This change has to be implemented on both C1 and C2 devices.
Hope to help
Giuseppe
06-25-2019 04:16 PM - edited 06-25-2019 04:26 PM
I fixed in other way..
i am learning default route as OIA so, i have option to set OIA administrative distance to 210 for inter area routes and got fixed. just avoided few lines of configuration :)
router ospf 1
distance ospf inter-area 210
Thanks and appreciated.
One more basic question : When we need mutual redistribution means, scenario with example!
Kumar
06-26-2019 01:34 AM
Hello Kumar,
OK you changed O IA AD on C1,C2.
mutual redistribution is really needed in cases like:
- IGP migration : for example you want to replace EIGRP with OSPF. At beginning you have only EIGRP running on all routers. You start adding configuration of OSPF on selected routers that form a block. At the border you may need to use mutual redistribution between OSPF and EIGRP to make the two routing domains to communicate.
This mutual redistribution is only needed during migration in the final network state only OSPF is running on all routers and these redistributions are not needed anymore and are removed and also the EIGRP is removed.
- a case similar to yours but using a default route in one protocol is not acceptable, because for example your default route needs to point to a different direction / different devices.
Hope to help
Giuseppe
06-22-2019 06:31 AM
Hello
If applicable cam you post a topology of your lab so its clear as to what actual setup you do have?
06-22-2019 10:12 AM
