Quick Question Regarding Software on a 7206VXR
keanej
Level 3
Level 3
Anyone know the difference between
The 'p' software
Like
c7200p-fpd-pkg.124-24.T7.pkg
c7200p-kboot-mz.124-24.T7.bin
c7200p-advipservicesk9-mz.124-24.T7.bin
and the software without the 'p'
c7200-boot-mz.124-24.T7.bin
c7200-kboot-mz.124-24.T7.bin
c7200-fpd-pkg.124-24.T7.pkg
It seems ours runs without the 'p' but I dont know if I should attempt to install the 'p' version.
Any Help Appreciated
James
2 Accepted Solutions
Peter Paluch
Hi James,
I believe that the 'p' versions are intended for NPE-G2 versions of the 7200 router. If you don't have NPE-G2 in your 7200 router you probably should not try to run the 'p' version.
Do you known the Cisco Feature Navigator tool? It's a great tool to use in these cases. Visit http://cisco.com/go/fn
Best regards,
Peter
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
only NPE G2 routers use 7200p image to boot.
NB: Also includes the 7201 (but not the 7301), I believe.
5 Replies 5
Peter Paluch
Hi James,
Best regards,
Peter
I have the NPE-G2 so I will order the 'p' versions
Thanks for the info
James
rajakalr
P as others discussed refers for NPE network processing engine -2 ie G2 which is a processor at the back of 7200
few images which are without p for 7200 router usually have G1(similar to G2 ) NPE -300,400 etc.
Disclaimer
Posting
Hello Joseph,
Correct - the Feature Navigator claims the same.
Best regards,
Peter
