traffic-export command in cisco 880 series router
sikusikanyika
hi,
i am trying to enable packet capture using the instructions found at Router IP Traffic Export Packet Capture Enhancements. i have managed all the instructions except towards the end. when i type:
Router#traffic-export interface fasteth0/0 clear
% Invalid input detected at '^' marker.
The command doesn't seem to be availble in this mode.
the command: sh ver gives
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 12.4(20)T5,
2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 15:58 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
any help to enable me proceed from here would be helpful.
thanks
vmiller
Level 7
Level 7
Restrictions for IP Traffic Export
Platform Restrictions
IP traffic export is intended only for software switching platforms; distributed architectures are not supported.
IP traffic capture is supported only on the Cisco 1841, Cisco 2800 series, and Cisco 3800 series integrated services routers.
