"boot the first valid file" not working
Petr Nyvlt
I have an issue with router 4321.
I set the "boot system" variable to load specific file on boot:
Router#sh bootvar
BOOT variable = bootflash:/isr4300-universalk9.03.16.06b.S.155-3.S6b-ext.SPA.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
The path is set correctly, it works fine when the file is present in the bootflash.
But I can't find solution to solve situation when this specified file is missing in the bootflash, but there is another valid image present.
Directory of bootflash:/
15 -rw- 489931744 Nov 23 2017 23:06:34 +01:00 isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin
According to this  Manual
  - If all boot commands in the system configuration file specify booting from a network server and all  commands fail, the system attempts to boot the first valid file in Flash memory.
But this never happened in my case. The router try to load the specified image and then reboot itself immediately:
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.2(2r), RELEASE SOFTWARE
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4321/K9 platform with 4194304 Kbytes of main memory
unable to open bootflash:/isr4300-universalk9.03.16.06b.S.155-3.S6b-ext.SPA.bin (14)
autoboot: boot failed, restarting...
Resetting .......
The config register is set to 0x2102, so it should be set correctly. Did I overlook something?
16 Replies 16
Leo Laohoo
Can you try a different IOS version?
You mean to load another "alternate image" on the bootflash?
Yes, I can try that, but I am sure that this one is OK. When I break the boot to rommon and boot manually it works fine.
rommon 1 > boot
Located FDO21252TBB_20171123175749575.lic
Unsupported package header version (1296383548)
Located tracelogs.027
Zero Image size
Located throughput_monitor_params
Unsupported package header version (-1347440721)
Located isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin
Package header rev 1 structure detected
IsoSize = 474769408
Calculating SHA-1 hash...Validate package: SHA-1 hash:
        calculated 8FE236DE:F1409C18:DF47B486:0DA50004:C0978CB8
        expected   8FE236DE:F1409C18:DF47B486:0DA50004:C0978CB8
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 5 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 6 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 7 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 8 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 9 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 10 contained errors which were auto-corrected.
%IOSXEBOOT-4-BOOT_SRC: (rp/0): mounting /boot/super.iso to /tmp/sw/isos
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Can you post the complete output to the following commands:
1.  dir
2.  sh run | i boot
3.  sh version
These are the outputs:
I have cleared all configuration except the boot command that points to non-existing image.
The router keeps restarting.
Router#dir
   11  drwx            16384   Jul 6 2017 03:18:58 +00:00  lost+found
16289  drwx             4096   Apr 9 2018 13:32:27 +00:00  .prst_sync
   12  -rw-             3261  Nov 25 2017 02:28:59 +00:00  FDO21252P8L_20171123175949576.lic
32577  drwx             4096   Jul 6 2017 03:20:01 +00:00  .installer
358337  drwx             4096   Jul 6 2017 03:52:16 +00:00  core
81441  drwx             4096   Jul 6 2017 03:50:27 +00:00  .rollback_timer
   13  -rw-                0   Jul 6 2017 03:50:36 +00:00  tracelogs.790
97729  drwx            12288   Apr 9 2018 13:25:26 +00:00  tracelogs
   14  -rw-               30   Apr 9 2018 13:32:25 +00:00  throughput_monitor_params
   15  -rw-        489931744  Nov 23 2017 21:30:37 +00:00  isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin
   16  -rw-               34   Apr 9 2018 13:34:30 +00:00  pnp-tech-time
   17  -rw-            14415   Apr 9 2018 13:34:32 +00:00  pnp-tech-discovery-summary
3149967360 bytes total (2498281472 bytes free)
Router#sh run | i boot
boot-start-marker
boot system bootflash:/isr4300-universalk9.03.16.06b.S.155-3.S6b-ext.SPA.bin
boot-end-marker
license boot level securityk9
Router#sh ver
Cisco IOS XE Software, Version 03.16.06.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 24-Jul-17 20:26 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2017 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 2 minutes
Uptime for this control processor is 3 minutes
System returned to ROM by reload at 15:25:02 MEST Mon Apr 9 2018
System image file is "bootflash:isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           appxk9           Permanent        appxk9
uck9             None             None             None
securityk9       securityk9       Permanent        securityk9
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4321/K9 (1RU) processor with 1648108K/6147K bytes of memory.
Processor board ID FDO2127A1VF
2 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
Router#
Hi Lee,
I have left the router to reloads repeatedly and it finally booted the first image on the flash:
It only took to much time and I was not patient enough
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
Resetting .......
no valid BOOT image found
Final autoboot attempt from default boot device...
Located FDO21252P8L_20171123175949576.lic
Unsupported package header version (1178943828)
Located tracelogs.790
Zero Image size
IsoSize = 474769408
Image validated
           cisco Systems, Inc.
software.
export@cisco.com.
 Parameter map cws-tunnel global not configuredcisco ISR4321/K9 (1RU) processor with 1648108K/6147K bytes of memory.
%INIT: waited 0 seconds for NVRAM to be available
Press RETURN to get started!
I guess the number 12 in the bootvar parameter is number of retries before it proceed to search for another image.
Router#sh bootvar
Is there option to reduce this number of retries?
I can't find this option in documentation.
Can you try changing the config-registry value to 0x2101?
Changing the configuration register does not fix that.
I made some tests and found out that this is ROMMON dependent behavior.
For System Bootstrap, Version 16.2(2r) that comes with "clock issue fixed" routers 4321
the ROMMON tries to boot the specified image 12 times, according to number set in the end of  BOOT variable:
BOOT variable = bootflash:/isr4300-universalk9.03.16.03.S.155-3.S3-ext.SPA.bin,12;
This lead to 12 reloads before router tries to search for another image in bootflash:
The old routers with "clock issue" came with  System Bootstrap, Version 15.4(3r)S5.
This version check the specified image only one time and then boot with first image available.
System Bootstrap, Version 15.4(3r)S5, RELEASE SOFTWARE
Copyright (c) 1994-2015  by cisco Systems, Inc.
Cisco ISR4321/K9 platform with 4194304 Kbytes of main memory
Directory isr4300-universalk9.03.16.03.S.155-3.S3-ext.SPA.bin not found
Unable to locate isr4300-universalk9.03.16.03.S.155-3.S3-ext.SPA.bin directory
Unable to load isr4300-universalk9.03.16.03.S.155-3.S3-ext.SPA.bin
boot: error executing "boot bootflash:/isr4300-universalk9.03.16.03.S.155-3.S3-ext.SPA.bin"
System integrity status: 00000610
File size is 0x1d348b60
Located isr4300-universalk9.03.16.06b.S.155-3.S6b-ext.SPA.bin
Image size 489982816 inode num 12, bks cnt 119625 blk size 8*512
 Unfortunately I did not find the way how to change the default number of retries (12) in the boot variable. The router boots in the end with some valid image from the booflash, but it takes quite a long time.
I'd raise a TAC Case. This is a strange issue.
Pls chk   sh run | i boot
boot system flash:isr4300-universalk9.03.13.08.S.154-3.S8-ext.SPA.bin  <--and remove
boot system flash bootflash:isr4300-universalk9.03.13.08.S.154-3.S8-ext.SPA.bin
System Bootstrap, Version 16.7(3r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Device not found flash:
Resetting .......
Resetting .......
Resetting .......
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 > dir
Incorrect Usage
rommon 2 > boot
Located isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
This post by Janaka above:
...was the solution for me.  I had a continual boot loop because I had incorrectly formatted the boot statement (in red), so I removed that and added the correct one (in green):
boot-start-marker
boot system flash:isr4300-universalk9.16.12.04.SPA.bin
boot system flash:isr4300-universalk9.16.06.04.SPA.bin
boot system flash:
boot-end-marker
boot-start-marker
boot system flash bootflash:isr4300-universalk9.16.12.04.SPA.bin
boot system flash bootflash:isr4300-universalk9.16.06.04.SPA.bin
boot-end-marker
Dear,
Check the IOS not got corrupted by checking MD5 value
show platform make sure all firmware matches
Boot system bootflash: .bin
I got same error after fixing this the issue got resolved.
Hello
The most simplistic solution i guess would to revert the boot variable to 0x2101 and then
state both ios bin files in bootvar with the primary IOS stated first.
res
Paul
Kind Regards
Paul
adazat5257
1. Boot to rommon.
2. Type 'unset BOOT'
3. Save the changes to nvram using the 'sync' command
4. Type 'reset' to reboot the system
Hope this helps.
