"cable length" commnad in a DS3 interface
Lijesh NC
Hi All,
Can some one tell me
1)The relevance of "cable length" commnad in a DS3 interface.
2)What exactly happens to the controller when we code this command into the interface,
3)Also what is the default, minimum and maximum cable length.
I tried to find some documents but littlle confused, in some documents its  mentioned default  length is 49 feet and in some 50 .What differentiates the default value wheather the card type of the thickness of DS3 cable.
Thanks in advance.
Lijesh.N.C
2 Accepted Solutions
paolo bevilacqua
1. little. in most cases things work anyway.
2. change output power level
3. different hardware may support different lengths.
In order not to saturate too sensitive receivers it may be necesseary to reduce output power level.
That is what what "cablelengt short" does.
5 Replies 5
paolo bevilacqua
Hi bevilacqua,
Thanks u so much for the information that was informative if you can elabrate the second one some more would be helpfull
2)change output power level
Lijesh.N.C
Its clear now.Thanks u so much.
Lijesh
You are welcome, thank you for the nice rating and good luck!
